Results 16 to 30 of 32
Thread: Correct way to check oil
    loganm is offline Competing with a gnat in reading comprehension. Current winner: Gnat. Arm chair racerAt the back of the pack
    Jun 2015
    Kansas
    364
    Check the HPOP maybe? Did you try installing an oil pressure gauge? Maybe you're not getting enough pressure and that'makes it smoke?
    On a serious note, slightly too much oil shouldn't make it smoke, if anything it'll puke some out the crankcase breather. Did you change type and viscosity of oil? That could affect it.
    ArizonaATC is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2012
    Eastern Canada
    163
    Quote Originally Posted by loganm View Post
    im not sure what the previous owner had in it but i put 10w-40 in it
    Mexico
    9,018
    If it stops leaking oil then you know you've run out
    It's not leaking, it's smoking. Try to keep up.
    It sucks to get old
    Mexico
    9,018
    The intermittent part is weird. Usually a worn engine smokes pretty consistently when hot. If you want to know if your rings are leaking (blow by) put your hand over the crankcase breather and rev the engine up. If you get good gust of air coming out your rings are likely toast, At the end of the day you'll need to tear it down as these kinds of problems don't go away.
    When you do pull it down have someone experienced near by. You have to find the problem, not just assume it was rings. It could also be a cracked head, or a worn valve steam/guide or seal.
    It sucks to get old
    Mar 2007
    Texas
    5,045
    to check the oil on an ATC, you unscrew the oil dip/fill screw. wipe it clean, then drop it back in w/o screwing it in, then pull out and check level.
    ________________
    https://www.mikesatvfix.com
    Jun 2015
    Kansas
    364
    That was a joke. I know it's hard to understand when someone is serious sometimes, maybe I'll put a disclaimer in my posts with jokes.
    Tionesta, PA
    5,747
    What color is the smoke? You mentioned replacing the bearings. Are you talking "engine" bearings? or Axle bearings?
    Nov 2012
    Eastern Canada
    163
    i ment axle bearings , i just ment i recently put some hours into working on it and got it rolling smooth then now it starts to smoke, one thing after the other lol -.-
    and the smoke isnt a heavy blue its kind of in the middle of blue and white
    Nov 2012
    Eastern Canada
    163
    yeah im gonna end up doing that very soon, my buddy is a competitive atv mechanic so il have him near by aswell.
    Nov 2006
    southern oregon
    2,338
    Quote Originally Posted by ArizonaATC View Post
    ever since i put new oil in 10-40 wet clutch my trike smokes on and off, when im out riding it will go from not smoking to a big cloud then go back to not smoking.
    Was it low on oil before doing the change? Do you know what type of oil was in it? Does the bike have the correct length dipstick? Filling crankcase with the correct quantity will verify dipstick. I would try a different oil before tearing into it. Non synthetic Shell rotella 15-40 has never caused a issue on any machine I've had.. And is also wet clutch approved
    2-stroke lover
    Nov 2012
    Eastern Canada
    163
    Quote Originally Posted by cr480r View Post
    im not sure on what type was in it as the previous owner put it in, it was in the safe zone so not low, and yes the oil i put in is rated for wet clutch
    Nov 2012
    Eastern Canada
    163
    im using formula 1 sae 10w-40 (ATV motor oil) rated for wet clutch, my other bikes i put this in seemed to like this stuff
    1979atc's Avatar
    1979atc is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jun 2015
    NW Ohio
    213
    My XR 200 does the same thing off and on. New valve seals, rings, honed cylinder and lapped valves. Does not smoke bad at all, smokes for a few minutes then stops. Then about 20 mins later it smokes a little, then goes away.
    1979 Atc 110 helm and son
    1977 Atc 90
    1980 Atc 110
    1984 Atc 110
    1985 Atc 110
    1988 XR 200 bored 40 over,
    Atc 200x bottom end.
    Nov 2012
    Eastern Canada
    163
    Quote Originally Posted by 1979atc View Post
    mines a little more than that maybe it will smoke for 5-10 seconds every 1-2 min
    but it varies sometime it will go 5 min with out smoking or only 30 seconds
  15. #30
    Nov 2012
    Eastern Canada
    163
    also i just went out and started it up and ran it for 5 mins or so and it didnt smoke once
