Results 1 to 15 of 15
Thread: Pistons
    ArizonaATC is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2012
    Eastern Canada
    163
    Pistons
    Do you guys think i should go with a stock piston or a wiseco, or any others? im gonna rebuild the engine and i want everything top notch and for it to last. any other advice on rebuilding an engine is welcome to
    Slidell, LA
    4,738
    buy a wiseco
    Nov 2012
    Eastern Canada
    163
    buy a wiseco
    more power from them, they good quality?
    Slidell, LA
    4,738
    Excellent Quality IMO. Wiseco offers 3 or 4 different compression ratios that you can purchase vs. 1 compression ratio with a stock piston.
    Nov 2012
    Eastern Canada
    163
    the higher the compression ratio the more power?
    Slidell, LA
    4,738
    increased torque and HP.
    Wiseco is great, never had an issue with them. I prefer OEM when available personally.
    Aug 2015
    Portland Oregon
    174
    Question Pistons; Forged or Cast
    Cast or Forged pistons; Sounds like you are going to run hard but not running the Snot out of your machine? Cast or OEM pistons would probably run just fine. If you want higher compression; you need to go to a forged piston the only ones offering them. Wiesco & Wossner are equally superior to cast pistons. There are many other brands of forged pistons which are lesser known; JE comes to mind.
    We’ve tested the 2 kinds of pistons & have found that forged pistons are more than twice as strong as cast pistons. If you want bullet proof strength; use a forged piston, any brand. See page 4, "How it's Done"
    For everyone’s information; .JE, Wiesco, & ProX are owned by “Performance Motors International” (PMI) who is owned by Dover Inc., DOV nyse. You can all own some Dover stock in the low $60 per share.
    John Tice
    503-593-2908 Alternate 541-508-3944
    www.smallenginemachineworks.com & www.nwsleeve.com
    Turning Custom Cylinder Sleeves Since 1971
    http://forums.everything2stroke.com/...d-the-Shop.com
    Mar 2007
    Texas
    5,045
    ok dumb question before I offer advice. What kind and sized motor? that is not addressed. there are different types of pistons I recommend for different motors and strokes.
    ________________
    https://www.mikesatvfix.com
    Nov 2012
    Eastern Canada
    163
    Quote Originally Posted by oscarmayer View Post
    this is a 1984 125m, was leaning toward the wiseco for a little more power out of her
    but need opinions on durability as well, for some reason some say the wiseco is better performance, but not as long lasting as the cast OEM ones, thoughts?
    Slidell, LA
    4,738
    Quote Originally Posted by ArizonaATC View Post
    False, with proper care and feeding a wiseco will last just as long as OEM.
    Mar 2007
    Texas
    5,045
    ^ what he said. I was not aware wiseco made a piston for the 125M.
    yup, just checked their site. no Wiseco for that motor. those were not sold for any sport for performance they were a trail/ranch puter with limited work capabilities back in the day.
    if you need to bore/hone the cylinder I recommend ebay for a piston and take what ever available. but get the piston FIRST before you have machine work done.
    here. best bet for you. it is larger than stock, so you can get your cylinder bored to match it. it also has a higher dome than your stocker so I would venture to saw more performance too. while your in it, you may consider replacing the front sprocket seals and sprocket itself. they wear and leak oil and the sprocket teeth wear causing chain slipping.
    http://www.ebay.com/itm/1984-1985-Ho...h-7wZg&vxp=mtr
    ________________
    Aug 2015
    Portland Oregon
    174
    Please explain, I don’t understand, we all learn together
    JT
    Slidell, LA
    4,738
    Hey john, above he said he heard that wiseco doesn't last as long as OEM and I simply stated that with proper maintenance a wiseco will last just as long as OEM.
    Aug 2015
    Portland Oregon
    174
    Thank you; there are always statements & opinions bouncing around the net with no reason or evidence to be true. If a statement is repeated enough people tend to believe it. It’s always refreshing to see more proof & understanding.
