Results 1 to 10 of 10
Thread: Tecate Ignition Options
    JMiller's Avatar
    JMiller is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    I need to replace my ignition system in my 87 T3. What options do I have? Is it a good idea to switch to a KX ignition system? If so, what year?My stator/ flywheel and CDI are all toast. What should I install now?
    Current Rides:
    '87 Tecate 3
    '84 Tecate 3
    JMiller's Avatar
    Anyone know?
    Current Rides:
    '87 Tecate 3
    '84 Tecate 3
    Oswego NY
    1,935
    I have a KX ignition in my 87. I am not sure what year it is. I know Kawi used the same crank in the KX as they did in the T3. If you do a parts search for crank simularitys that will tell you what has the same keyway for the flywheel. After that you just need the complete KX ignition, flywheel, stator, and CDI.
    Thata about all I can tell you. I know others have done the same research, they will post as they get to it LOL
    GOOD LUCK
    MIK6 / Mike
    New England Ride 4/13
    Mar 2003
    NJ
    911
    200x basket and Jeb have KX ignitions i think. The only thing is you cant run lights unless you get some kind of add-on. There is also the Ricky Stator option for around $200.
    86 KXT250B1 (4)
    87 KXT250B2
    85 ATC250R
    85 ATC350X
    84 ATC200S
    87 Banshee
    96 ZX7R
    May 2002
    Texas
    2,670
    Actually I don't currently have a KX ignition. I did have one on an 85 KXT I had in the past. I do recommend the KX. If you want lights, you'll have to look at adding a lighting coil to the KX stator.
    1986 Tecate
    1984 Tecate
    1985 Tri-Z
    1986 ATC350X
    1985 ATC250R (2)
    1985 ATC125M (2)
    1982 ATC70 - Original Owner
    175 TriMoto Frame with Pro-Tec Rear Suspension
    3-Wheelin' since '82
    Jul 2003
    936
    jeb...what year KX fits the 85 t3 and what is the benefits/drawbacks?
    Wanna race? ;-)
    85' Tecate (still looking for entire front brake asembly...)
    bonanza mini-bike
    if you cant ride with the big boys...put it back on the trailer
    May 2002
    Texas
    2,670
    Quote Originally Posted by TeCaTe_MaN
    For sure 83/86. I'm not sure what year the one I had was. probably any of the 80's models. I've been told you should use the whole ignition. The KX system is more robust. you must use the stator and flywheel for sure. I've got a Tecate set up manual (JWR) that says to switch to the KX coil too.
    You should see better throttle response from the KX ignition. and you can forget about magnets coming loose and stators going out. If my 86 KXT fails again, I will probably more than likely switch to a KX. Although, I had stators in the past rewound for $75 and magnets re-glued for $75 too. And Ricky Stator is offering a better value than stock on his replacement stators and flywheels.
    1986 Tecate
    1984 Tecate
    1985 Tri-Z
    1986 ATC350X
    1985 ATC250R (2)
    1985 ATC125M (2)
    JMiller's Avatar
    Do you have to change the CDI also?
    Current Rides:
    '87 Tecate 3
    '84 Tecate 3
    Jun 2002
    Mississippi
    2,552
    you have to change it all. it works great and no more stator problems.
    83 ATC70
    85 ATC70
    85 200x vintage racer
    86 500r
    Lots of parts
    My 500R
    Dec 2002
    749
    Sorry to bring back an old post but can anyone help me out with what year kx ignitions will work in the 86 T3? I mean while the engines out of my T3 and its going through the resto I might as well replace this stuff so I wont have to worry about stator problems in the future.
    3WheelsForever / Virgil
    TrikeFest 03, 04, 05, 06, 07
    1985 Honda ATC350X - TF2015 Project
    YZ426 Hybrid Trike - On the back burner
