Results 1 to 2 of 2
Thread: 1984 125m no 4th gear need some help
    Jan 2015
    Muhlenberg county, KY
    129
    I just got a 84 125m I know these have granny problems but I haven't seen anything like this before this bike shifts down into 1 2 and ers gears but when you hit 4th it's in neutral again is like to k nsow that someone else had had this problem and if so someone please give me some info thanks in advance
    6,811
    Sounds like the typical shift drum stopper issue to me , probably going In between 3rd and 4th gear , which will act like its in neutral.
    Remove the clutch cover an inspect .
