Thread: Carb for my atc 110
    May 2016
    Valdosta,Ga
    11
    Carb for my atc 110
    I was looking for a new carb for my 110. I found one on ebay and was wondering if it was a good fit.Click image for larger version.
ID:	231883 this is the carb.
    1979atc's Avatar
    1979atc is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jun 2015
    NW Ohio
    213
    Quote Originally Posted by Joshua81 View Post
    If you are running a stock 110 you can't run this carb, it would run poorly trying to keep up with the amount of fuel you are giving to the motor. If you were to use this carb on a hi performance 90/110 you would need a aftermarket intake manifold so the bottom of the carb could clear the cylinder.
    1979 Atc 110 helm and son
    1977 Atc 90
    1980 Atc 110
    1984 Atc 110
    1985 Atc 110
    1988 XR 200 bored 40 over,
    Atc 200x bottom end.
    May 2016
    Valdosta,Ga
    11
    Thanks, i just wanted to make sure before i bought it.
    Sent from my SM-G920P using Tapatalk
    May 2016
    Valdosta,Ga
    11
    I do want more power out of my 110 but i dont know where to start, so i think i may just rebuild it stock.
    1979atc's Avatar
    Jun 2015
    NW Ohio
    213
    No problem, just get a stock carb and you should be golden.
    1977 Atc 90
    1980 Atc 110
    1984 Atc 110
    1985 Atc 110
    Mar 2016
    Carbondale, IL
    43
    I bought this carb for my ATC 110, and it works great. It is a direct bolt-in replacement in every way except that the tube on the top that the throttle cable passes through wasn't the right diameter. The cap to the old carb threads on to this one perfectly, though, so if you have that still then you can just continue to use it and it will be a perfect match.
    I made a bunch of posts on here about carb issues, but it turns out that it was actually my ignition timing all along. Once I fixed my ignition timing, this carb worked perfectly.
