Results 1 to 15 of 16
Thread: Making square holes for carriage bolt heads
    May 2009
    S.E. Michigan
    1,251
    I'm putting tie-down anchors on my trailer. I bought a bunch and they are drilled with 1/4" holes. I want to use carriage bolts and so need to make the holes square. I used a triangular file to square off the edges of the two holes on one of the 8 anchors I want to install, but holy cow is it a pain. Is there any easy way to do this?
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    Mexico
    9,018
    An iron worker with a square punch is the ticket. You're a wild man if you plan to square a round hole with a file.
    What about welding bolts to the anchors to keep them from turning? Another option might be to drill a round hole just big enough that you could the carriage bolts into them and they wouldn't turn.
    It sucks to get old
    Jan 2015
    LaGrange, OH
    253
    Wow that's gonna take some serious elbow grease! I'd use a die grinder if you want to just do it yourself.
    Oct 2013
    Wherever I May Roam
    3,757
    Porting tool with the right bit would get ya close.
    Jan 2011
    Choctaw, OK
    2,755
    I have seen videos of bits that drill square holes. https://www.youtube.com/watch?v=ALiqAXiTQBg
    Jan 2011
    Choctaw, OK
    2,755
    May 2009
    alabama
    68
    Depending on the size of the hole, a jigsaw with a blade for cutting metal. Drill your round hole & finish out with the jigsaw
    Sent from my SM-G920V using Tapatalk
    Aug 2015
    Idaho
    838
    I believe you have the way, wonderboy. A file and patience!
    RUNMEDOWN is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2006
    Omaha Nebraska
    321
    I have a file that has a sawz-all connector on it, Home depot had it. You may want to look into that, makes it much easier. Snap it in the sawz-all and have at it.
    85 ATC110 - The Greatest ATC of all time - (My First - new in 85)
    83 FL250 - Odyssey w/420cc - SOLD
    82 185s -10.25:1 piston, Full 200x upper, Goki Electric start - SOLD
    84 200x - Auto-X - Weisco Hi-comp, Cam'd, Bassani'd, Westcoast swinger, -SOLD
    82 200E Big Red -SOLD
    85 ATC250ES Big Red - Snow Plow !
    May 2009
    S.E. Michigan
    1,251
    Quote Originally Posted by RUNMEDOWN View Post
    I'm going to have to look for that!! I was imagining something like this would make quick work of it. I may search for a die grinder bit too, but it would have to be pretty small diameter...
    Thanks for the advice!
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    Austin, Massachusetts
    1,591
    square drill bit
    Wubba Lubba Dub Dub!!!!!
    TRIKES:
    86 250r
    85 250sx
    86 250sx
    85 Yama 225DX - The Rental!
    150cc Piranha powered 70
    110cc Lifan 70
    82 70
    83 ALT 50 Trail Buddy
    88 Yamaha BW 80
    84 z50
    Aug 2015
    Portland Oregon
    174
    The suggestion of using a larger hole just big enough to catch the 4 corners. Drill a few sample holes to determine what size drill that you need. Smack the bolt home with a heavy . If the material is thick enough, a square broach would be the best choice.
    JT
    Mexico
    9,018
    Quote Originally Posted by Flyingw View Post
    That's wild!
    It sucks to get old
    250rAL is offline Just Too Addicted Arm chair racerJust too addicted
    Sabula,IA
    620
    Carriage bolts are made for wood. I think I'd use a little better grade of bolt for such an important item as a tie down point.
    __________________
    '85 ATC250R
    .030 Over Wiseco
    FMF Pipe/Answer silencer
    36PJ Keihin
    K&N
    Boyesen reeds
    Magura hydraulic clutch
    Roost Boost
    MSR bars
    OMF swingarm skid
    ITP Beadlocks
    Three Wheelin' Since '84
    Mexico
    9,018
    Quote Originally Posted by 250rAL View Post
    They may have been used first in wood, but you can get high grade carriage bolts if you want them. Grade A449, which is equivalent to A325 (structural bolts)
    It sucks to get old
