Thread: Big red 200e engine on ATC 185s
    Feb 2015
    Catawissa, Missouri, USA
    138
    I just picked up a big red engine, from a 1983 200e and I plan to swap it to my 1983 ATC 185s. Any idea how difficult this will be, and will I be able to keep the starter? What will I have to do to get it to fit?
    Never forget the past , but dont dwell on it.
    My toys
    Trike:
    1983 Honda Atc 185s (update: frame painted!)
    1986 honda Atc 125m (sold)
    Non - trike
    1968 Lomart Cheeftah Mini bike (3 hp Tecumseh)
    1968 wheel horse charger automatic ( modded)
    1981 Dodge Power Ram (driver)
    1981 Imperial (project car)
    Follow me on my blog! (Yes, its about trikes!) https://www.tumblr.com/blog/atctriangleofdeath
    RUNMEDOWN is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2006
    Omaha Nebraska
    321
    to keep the starter you will need to notch the frame a bit on the down tube. I heated and bent mine (200x) and then welded in a DOM tubing as a sleeve to give more strength (200xs like to break there), with a 185s you may just be able to ding it out with a and some heat.
    85 ATC110 - The Greatest ATC of all time - (My First - new in 85)
    83 FL250 - Odyssey w/420cc - SOLD
    82 185s -10.25:1 piston, Full 200x upper, Goki Electric start - SOLD
    84 200x - Auto-X - Weisco Hi-comp, Cam'd, Bassani'd, Westcoast swinger, -SOLD
    82 200E Big Red -SOLD
    85 ATC250ES Big Red - Snow Plow !
    Feb 2015
    138
    Picked this up for $60, essentially the whole big red, minus seat, front fork, and a few pieces. 1983 200es, the fenders are from a 200m
    Would it be better to try to put this engine on my 185s, or else get a front fork and put the big red together?
    My toys
    Trike:
    Non - trike
    Feb 2015
    138
    ok, apparently, 1983 Big Reds do not have reverse. Incidentially, can the Reverse Setup be used from an 84 or not? also, the high/low setup is missing from mine, the output shaft from the engine and the gear from the high/low is there, but the rest of the subtrans is gone, anyone have one?
    My toys
    Trike:
    Non - trike
