Page 10 of 10 FirstFirst ... 8 9 10
Results 136 to 144 of 144
Thread: Another one...
  1. #136
    loganm is offline Competing with a gnat in reading comprehension. Current winner: Gnat. Arm chair racerAt the back of the pack
    Jun 2015
    Kansas
    364
    I am getting a clanging noise at idle and kind of rattle at speed. Still a fresh top end and they said they checked clearances and they were good. Only mechanical thing I can think of is maybe counterbalancer bearings??? Waiting for this video to upload. How noisy are these engines?
    It's boggy today too, but it's ~80F and humid AF, so I'm guessing the humidity is why it's running rich?
  2. #137
    JacobMonster's Avatar
    JacobMonster is offline At The Back Of The Pack Arm chair racerFirst time rider
    May 2015
    Liberty, Ky
    232
    Quote Originally Posted by loganm View Post
    When i was at TF, a lot of them had the same rattle-y noise mine did.
    one guy said his made the same noise before his main bearings went. I know my kick starter rattles a bit.
    Sent from my SAMSUNG-SM-G530AZ using Tapatalk
  3. #138
    Jun 2015
    Kansas
    364
    Kicker rattles but holding it makes no difference. I know it's gonna make some noise, there's an explosion going on in the cylinder multiple times a second. The clanging doesn't make sense. If it were pinging wouldn't that be more under load? It goes away after idle and turns into a rattly noise. It's still a fresh piston so unless they bored it wrong and lied to me about it I have no idea.
  4. #139
    May 2015
    Liberty, Ky
    232
    Only thing I can think of is main bearings and a bad crank. When I took apart my first 250R, one bearing was completely out and the other was bad by a small amount. Rod specs I believe are .026 or .028-.032. Mine was at .034. My other 250r has the same noise. The engines are generally loud from what I've been told. I would check rod clearance.
  5. #140
    Jun 2015
    Kansas
    364
    Crank and rod bearings are good, spin smooth, no play. Top end looks like pictures previously posted... Wtf!!! Should I call them out on this ? Kinda really annoyed rn.
  6. #141
    Grand Rapids, MI
    522
    OK bud.. who's doing your work? Might be time to get a new, quality place for your repairs...
    I doubt, if you took it back apart to check out the bearings / etc will they do anything for you now... Maybe they will... IDK.
    If it were me, and it was making all the racket you were describing, I would have brought it back to them running and had them listen to it. If they would have told you "it's normal", get it in writing and hold them to it. If they won't stand behind their work, then obviously you need a new place.
    Gunter glieben glauchen globen
    The Good:
    1985 1/2 Tri-Z - Daily Rider - Pretty much stock ( wink )
    1985 1/2 Tri-Z - Custom Black & Gold, Top mount plastic tank, custom 3D printed airbox, Banshee shock
    1985 Tri-Z - Rider restore in process
    The Bad:
    1988 TRX250R with 86 ATC 250R Motor and Swinger - Screamer!
    The Ugly:
    1993-ish Banshee / 2003 Motor by VSR in Belding, MI - Duner Fun!!
    2000-ish Banshee / Motor by RDZ Racing in Fowlerville, MI - Another Duner!
  7. #142
    Jun 2015
    Kansas
    364
    Well, I don't have to tell them I've taken it apart... I'm gonna call them tomorrow and not mention that, and I'll see what they say. If it fries another piston I'll send it to someone here or Allen knowles since he did my crank.
  8. #143
    Jun 2015
    Kansas
    364
    Also, it doesn't look like the piston ever came in contact with the bore. It has some light scratches on the intake and exhaust side, the kinda light scratches you get when you run the piston through the bore dry because you're curious what .020" actually looks like in the bore (compared to the old piston).
    Only other thing could be my air filter is just a POS. I cleaned and piled it with the k&n stuff, but it came with the bike so idk.
  9. #144
    Jun 2015
    Kansas
    364
    If anyone was wondering I sold it a long time ago. Most likely my issues were related to running a straight air filter with no airbox.
    Anyways don’t own a trike anymore, dabbled in drugs, mental illness, and a toxic relationship with someone as insane as me for a while. Now have a 97 kx250 I’m building and a 18 yz 250 that is my main. Trying to go race motocross, I mostly ride at bar2bar. I will probably never log on again feel free to delete this account.
