Results 1 to 7 of 7
Thread: 85 Tri z Fork Rebuild Kit
    Oct 2013
    Huron Ohio
    54
    Anybody Know of a complete rebuild kit bushing and seals? Maybe a dirtbike kit off of something else will also fit year and make? These are the 35mm forks
    85 350x
    85 Tri-z
    Mexico
    9,020
    I don't know of a kit, onF1 (Milner) might. You can still buy OEM piston rings and seals for those forks.
    https://www.rockymountainatvmc.com/oem-schematic/4
    It sucks to get old
    Oct 2013
    Huron Ohio
    54
    Thanks El Camexican I seen all the rings and oil seal is still available oem except dust seal didn't know if there is a fork rebuild kit cheaper maybe for a dirt bike or something believe it or not the rings don't seem that bad of shape
    85 350x
    85 Tri-z
    Aug 2014
    South Louisiana
    1,915
    Quote Originally Posted by smrover1 View Post
    I think Milner mentioned in a previous thread that the bushing from 83-84 250r swap into the tri-z forks. Not 100% sure though.
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
    Surprise, AZ
    2,428
    OEM stuff is the best, if you use them you will save money in the future. The OEM Honda 350X dust seals are a major upgrade and they are available. Please don't use ATF in the forks.
    Oct 2013
    Huron Ohio
    54
    Thanks for all the info I was planning on using the Belray 10w I also have access to nitrogen at work also. I was shocked the manual said 0 air psi was std
    85 350x
    85 Tri-z
    Surprise, AZ
    2,428
    Save the Nitrogen for the tires.
