Anybody Know of a complete rebuild kit bushing and seals? Maybe a dirtbike kit off of something else will also fit year and make? These are the 35mm forks
85 350x
85 Tri-z
I don't know of a kit, onF1 (Milner) might. You can still buy OEM piston rings and seals for those forks.
https://www.rockymountainatvmc.com/oem-schematic/4
It sucks to get old
Thanks El Camexican I seen all the rings and oil seal is still available oem except dust seal didn't know if there is a fork rebuild kit cheaper maybe for a dirt bike or something believe it or not the rings don't seem that bad of shape
85 350x
85 Tri-z
"Roll on 3"
RIP Ol' Deuce
"Long Live the ATC"Building: ATCr125xRiding: ATC200sx"I am not a mechanic, mechanics get paid for this. I do it because I enjoy it."
OEM stuff is the best, if you use them you will save money in the future. The OEM Honda 350X dust seals are a major upgrade and they are available. Please don't use ATF in the forks.
Thanks for all the info I was planning on using the Belray 10w I also have access to nitrogen at work also. I was shocked the manual said 0 air psi was std
85 350x
85 Tri-z
Save the Nitrogen for the tires.
