Results 1 to 8 of 8
Thread: 350x swingarm bearings
    22LB is offline New to the board Arm chair racerNew to the board
    Dec 2011
    Indiana
    24
    Trying to get the bearings out of swingarm where the bolt goes through. I used a socket and sledge and got them to move an inch or so seams like they wont move anymore. Will those beat out either way or is there some type of lip in there to keep bearings from sliding
    Dec 2011
    Indiana
    24
ID:	232139 cant seam to get them this point
    Jul 2015
    Maryland
    16
    It looks like you're stuck with just the outer cage for the roller bearings now?
    On my 200X, I got down to that point and ended up having to use a sawzall to cut through the race to get the rest out. (this was after I tried the socket/extension/ method and heat). I'm sure it goes without saying, but take it easy and be careful not to cut into the swing arm itself.
    Also, when I went to put the new bearings back in, I tried to "gently" tap them in with a dead blow with a bunch of grease for lube. All that did was deform the bearing cage and destroy the bearing. When I got my second set of bearings, I ended up using the stock swing arm bolt and a big washer to draw the bearing into the swing arm.
    May 2016
    Detroit
    29
    Both of my bearing races were stuck and rusted in my frame so bad when I did my swing arm bearings, I thought there was no way they would ever come out. What finally worked for me is heating them with a propane blow torch until the bearing is almost red hot or for a few minutes, then shocking them with PB blaster. The heat helped break the bearing races free and the penetrating oil cooled the races allowing them to shrink just enough to let the penetrating oil soak in. Came right out after doing that.
    Cutting them will work as well, as mentioned previously
    Dec 2019
    Long Island
    85
    I know this is an old thread but I've tried both previously mentioned methods. When I went to remove the bearings, there was nothing to remove but a thin wall of steel left from the bearing race. What you see in the pics is all that was in there. The one pic is from the side I was working on. Is the swingarm even salvageable? I tried the torch and PB method, I've cut one with a Sawzall and mini hacksaw. It looks like its all the way through but its starting to score the swingarm. (I cut it even more after I took the pic) I beat them with an impact socket (destroyed) and even rapped it a bunch of times with a cold chisel. It seems as if its welded to the swinger. Any other options? Thanks guys.Click image for larger version.
ID:	265212Click image for larger version.
ID:	265213Click image for larger version.
ID:	265214Click image for larger version.
    In the garage
    2007 Yamaha Tri-Z 450
    2017 YZ 250F
    2003 XR100 (son's)
    2005 Raptor 350 (other son's)
    Gone but not forgotten
    86 350X
    16 WR 250R
    03 FZ1
    96 Katana 600
    89 XT350
    84 250R
    84 200X
    79 ATC 110
    74 ATC 90
    Willamstown PA
    5,824
    Use head, and a socjwt and punch, they will come right out. Just always use head, najes any job easier.
    Dec 2019
    Long Island
    85
    Not exactly sure what this means
    In the garage
    2017 YZ 250F
    2003 XR100 (son's)
    86 350X
    16 WR 250R
    03 FZ1
    96 Katana 600
    89 XT350
    84 250R
    84 200X
    79 ATC 110
    74 ATC 90
    Apr 2006
    SE CA Dez in the sandbox
    899
    Just replaced the same on my 350x swingarm. Tried everything. Used a cutting torch with a small tip and vary carefully cut what was left of the bearing out.
    Replaced with Delrin bushings. Won't have that problem again.
    Have '85 350X-XR500 Hybrid,
    Had Nicholson framed: 90/110, 185s, Gen I 500, Gen II 500
    Had Bandito Framed 90
    Have Vey's Framed 90
    Have too many parts
