Page 3 of 3 FirstFirst 1 2 3
Results 31 to 37 of 37
Thread: Handlebar Vibration
  1. #31
    250ES5984's Avatar
    250ES5984 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Oct 2011
    Alabama
    199
    Top end or bottom end you think?
    1986 Honda 200x
    1985 Honda 250sx
    FOR SALE
  2. #32
    Mar 2007
    Texas
    5,045
    Well you have to take the top apart to get to the bottom, so start there.
    Before you do, have you done a valve adjustment?
    ________________
    https://www.mikesatvfix.com
  3. #33
    250ES5984's Avatar
    Oct 2011
    Alabama
    199
    No, I haven't. Nor do I know how. I do have a shop manual and will be rebuilding the top end in the next month or so, so I'll learn how.
    1986 Honda 200x
    1985 Honda 250sx
    FOR SALE
  4. #34
    Mar 2007
    Texas
    5,045
    valve adjustment is stupid EZ. the 1 round caps on the top of the motor. unscrew them. make sure the engine is at TDC by looking through the smaller hole on the stator cover and by hand rotate the motor till you see a T align up with the line on the edge of the hole.
    now take a feeler gage, (I like to bend mine up at a 30-40* angle about 1" from the tip so it is easier to get in and out) you want .003" gap and slide it under the rocker arm above the valve tip. it should slide in with slight resistance but not like it is very hard to do so. if it is really loose in there your gap is too big, if you cannot get it in there, then the gap is too tight. you just loosen the nut right there ont he rocker, loosen the rocker screw in tip till you get it where it should be and re-tighten the nut to lock it in place. do the same to both sides.
    manually will show you more details. .003 is in the middle for both intake and exhaust so I I run that for them typically.
    I was wondering if the valves are too tight they could be causing the vibration as well.
    ________________
  5. #35
    250ES5984's Avatar
    Oct 2011
    Alabama
    199
    Quote Originally Posted by oscarmayer View Post
    I could see where the valves being too tight could cause it to vibrate.
    1986 Honda 200x
    1985 Honda 250sx
    FOR SALE
  6. #36
    Mar 2007
    Texas
    5,045
    any news yet?
    ________________
  7. #37
    250ES5984's Avatar
    Oct 2011
    Alabama
    199
    any news yet?
    I'm on vacation right now. Actually will be heading home in a couple hours. I plan to tear into it sometime towards the end of this month or beginning of next.
    1986 Honda 200x
    1985 Honda 250sx
    FOR SALE
