Results 1 to 13 of 13
Thread: 84 200 won't start. Help!!
    May 2016
    Canada
    6
    Question 84 200 won't start. Help!!
    My 84 200 won't turn over, the compression checks out at 120, there's a coil that we know is good on there and the carb just got rebuilt. I have no idea what to try now. Any ideas?
    Slidell, LA
    4,738
    1. Does it have a bright blue spark?
    2. Does it have a very clean air filter with no obstructions in the intake tract?
    3. Are there fuel deposits on your spark plug?
    May 2016
    Canada
    6
    No fuel at all on the spark plug! And everything else is good
    Slidell, LA
    4,738
    I would say to look at your carb again. Is there fuel in the float bowl?
    May 2016
    Canada
    6
    I'm not home now but I know you can smell the gas pretty easily when we crank it. It even sprays out of the carb..
    Slidell, LA
    4,738
    if you smell gas to the point of flooding and you don't see fuel on your spark plug, something isn't right. If you smell gas you should be seeing it on your plug.
    averysdad is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jan 2013
    Cleveland, tx
    218
    If I remember right I had one do something like that and it had a bent valve. But I would just follow the steps yaegerb gives you. May not be a bent valve at all.
    May 2016
    Canada
    6
    Yeah that's what we were kinda thinking.
    Jan 2013
    Cleveland, tx
    218
    I'm no expert wait for yaegerb to reply. On second thought If the valve is bent I don't think it would have good compression.
    Slidell, LA
    4,738
    Before you go on a wild goose chase make absolutely sure you have excellent spark (blue), fuel moving into your cylinder (showing on spark plug) and adequate air flow (filter and intake track to carb bell isn't restricted). It will fire with those three elements, though, may run irradically if something else is wrong.
    From what you have said so far I am thinking that you are getting fuel on spark plug (if you smell gas it should be present ) and your spark isn't as strong as you think it is.
    Course, I have seen some weirder crap happen.
    May 2016
    Canada
    6
    The spark plug is always dry after we try and turn it over, we even put fuel directly in the hole and nothing happened. The spark is bright blue so what else could cause that?
    Slidell, LA
    4,738
    if it's not firing when you put gas in the hole then your spark isn't strong enough to ignite the fuel or the motor is out of time.
    The "dry spark plug" with flooding smell has me perplexed. I would still crack the float bowl puke screw and ensure gas is in your bowl and go so far as to remove the carb, shine a light in the cylinder to ensure there isn't an obstruction.
    May 2016
    Canada
    6
    Alright I'll try that. I appreciate your help!!
