Ok after about a million dollars put into it, I have yet another problem. Here's the story... One day I went out to start it, it would run for a while then shut off. I thought it was the carb so I took it apart and put it back together but still had the same problem. Well eventually I found out it was the kill switch wires grounding to the frame so now it would stay running but back with that came another problem. It won't idle at all, if I barely hit the throttle it will rev sky high then bog down and die. When it is wide open (even if I just snap it open) it will pop and crack. My first thought was an air leak. Nope. I even used silicone and tightened the bolts down as tight as they would go and it still did the same thing. I checked all the wires, readjusted the valves, checed for exhaust leak, took carb off again and let it soak in cleaner, played with the carb settings, checked for a sticking slide, checked for clogged vent tube, the fuel lines aren't clogged, petcock isn't clogged, and I played around with the ignition timing and absolutely nothing helped. What gets me is this thing was running PERFECT before the kill switch wires messed up and I'm kicking myself in the a** really hard for taking the carb off. I have just ran out of options and need help from you guys. If I get this fixed and something else goes wrong, it's outta here. I've had enough.
