Results 1 to 8 of 8
Thread: 1976 Honda 90 ATC looking for ignition coil
    Oct 2014
    Wisconsin
    4
    I acquired my second ATC and hoping someone can help me find an ignition coil (including plug wire) for my new to me 90. The ones I see on ebay look different. Any help finding one would be greatly appreciated. Thank you
    [IMG][/IMG]
    [IMG][/IMG]
    arlaunch's Avatar
    arlaunch is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2014
    Oregon City
    346
    Cool machine!
    Seems service Honda sells the plug cap for the 77.
    I can't find the wire or the coil out there though...
    Let us know when you get the thing running.
    1984 Honda Big Red ATC 200ES (Emma)
    1985 Honda 200X ATC (Pretty Boy)
    1985 Honda 250R ATC (Dr. Fast)
    1985 Honda 250R ATC ( 77 )
    1985 Honda 250R ATC (Baller)
    1986 Honda 350X ATC (Go Go Girl)
    Feed Back: http://www.3wheelerworld.com/showthr...k-for-arlaunch
    sanchez's Avatar
    sanchez is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2009
    where ever i may roam
    228
    Look different works the same hides under fuel tank. Just buy the China coil an run it.
    Appearing since '07
    Looking for a place to happen...
    Making stops, along the way
    Oct 2014
    Wisconsin
    4
    Thanks, I'll try a China unit and let you know how it goes.
    NFN
    Feb 2016
    Stellenbosch, South Africa
    192
    I agree with getting a Chinese unit, they work well and cheap to replace ...
    1983 Honda ATC250R
    1983 Honda ATC200E BIG RED (sold)
    1984 Honda ATC200E BIG RED
    1984 Honda ATC200X (sold)
    1985 Honda ATC70 x 3
    1985 Honda ATC250ES BIG RED
    1986 Honda ATC250ES BIG RED
    1988 Honda ATC250ES BIG RED
    1995 Honda Frankentrike 50cc 2-stroke
    2001 Honda TRX90
    2004 Honda TRX300EX (sold)
    2008 Honda TRX250TM
    1976 Suzuki RV90M (sold)
    1967 Vespa Primavera 125
    1958 Massey Ferguson 35
    Oct 2014
    Wisconsin
    4
    Having issues with this 90. I tried a new 6V coil but can only get a really weak spark that you can barley see or feel. I'm starting to look at replacing the stator. The last person I know that saw this wheeler run said that it was slow and the head light would only work with the rpms up. Does that sound like a stator?
    Sep 2015
    Dry side of WA, USA
    16
    That bike's a survivor! Great find there
    I hope it's helpful to share a small fact about ignition coils I was reading.
    There are two different types of coils, one which is energized by the battery, and the other which is energized by the stator(I want to call that a magneeto, but my terminology might need improvement). Might be a good thing to check into for yours.
    When you mention a 6v coil, I went to thinking maybe you have the type meant for a bike with a battery.
    This tip here is slick:
    You can totally replace your points with an electronic ignitor. I just did this successfully on my ATC70 using two different units:
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    is the one I recommend, because its self grounding and easier to hook up because its slightly smaller.
    The first one I purchased, also worked fine:
    I do also have weak spark, but I'll report back after I've tried some things to remedy that issue:
    *Swap coil from another bike, making sure the grounds are good.
    *New spark plug cap, the one on there is half gone.
    *Lastly I'll try swapping flywheel from another bike
    Hope this helps, at least I've got lots of enthusiasm for that machine.
    Nothing compares to spinning donuts, and sliding around corners in the snow on those things
    Have fun!
    Don
    Mar 2019
    Evansville IN
    What coil did you end up using??? I have the same ATC with the same issue.
