Results 1 to 15 of 23
Thread: 82 Air Fooler Exhaust Install Issues
    JacobMonster's Avatar
    JacobMonster is offline At The Back Of The Pack Arm chair racerFirst time rider
    May 2015
    Liberty, Ky
    232
    2nd 2-stroke machine I have ever owned, and the first one I'm working on.
    I have another 82 in pieces at the moment.
    So, I picked this sucker up for $820 with new rear 20 inch tires on Douglas rims, Pro Taper bars, and all the skid plates. Heres my issue.
    Front exhaust flange was leaking oil and the bike was really loud, as if the header wasnt hooked up properly.. I thought maybe the exhaust was not seated correctly.
    So I changed them out with another stock set and heres the problem.
    My mounts dont want to line up when I fully seat the header pipe on the flange. Only the front most mount and the top muffler mount will sit in the right place.
    My question being, should this exhaust header be seated completely on the flange, or is it made to sit partially on there?
    Or am I just an idiot and I need to adjust the mounting brackets to make it fit?
    Thanks for the input.
    Slidell, LA
    4,738
    that pipe should fit all the way on the flange. Pipe may be bent and/or massaged to fit on correctly.
    Carthage NY 250r rules
    2,355
    You need rubber mount like the top has on the silencer.And your flange should be seated all the way.Your whole exhaust system should be mounted to the frame with 4 of the mounts like the top rear.2 on the headpipe and 2 on the silencer.
    250r rules
    arlaunch's Avatar
    arlaunch is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2014
    Oregon City
    346
    This link may or may not help?
    Also,
    You are not an idiot.
    Don't forget to reference the manual for each and everything you do.
    When you get things lined up, don't forget to use high temp silicone.
    RTV makes it and sells it in your local auto store for around 7-8 dollars. I use it to seal the header pipe to the head and the exhaust pipe too.
    https://www.piperepair.com/tips.htm
    1984 Honda Big Red ATC 200ES (Emma)
    1985 Honda 200X ATC (Pretty Boy)
    1985 Honda 250R ATC (Dr. Fast)
    1985 Honda 250R ATC ( 77 )
    1985 Honda 250R ATC (Baller)
    1986 Honda 350X ATC (Go Go Girl)
    Feed Back: http://www.3wheelerworld.com/showthr...k-for-arlaunch
    May 2015
    Liberty, Ky
    232
    Quote Originally Posted by atc300r View Post
    I have the other rubber mounts. A few have dry rotted. I'll fiddle with it more this weekend when Im not mad at the bike.
    I'll see what I can do this weekend and get back with you two.
    Sent from my SAMSUNG-SM-G530AZ using Tapatalk
    May 2015
    Liberty, Ky
    232
    Quote Originally Posted by arlaunch View Post
    Also,
    Thanks for the tip Forrest.
    I constantly forget I have the manual on my computer :/
    That link is also going to help a looooooot.
    Slidell, LA
    4,738
    Quote Originally Posted by JacobMonster View Post
    I disagree with using silicone on an exhaust flange, but do what you need to.
    May 2015
    Liberty, Ky
    232
    Reasons for the disagreeing?
    arlaunch's Avatar
    Jun 2014
    Oregon City
    346
    I have lots of respect for YaegerBob!
    With care i will post my reasoning for using High Temp Silicone.
    Note: The attached pic below is from the Duncan Racing instructions/installation for a PT High Rev pipe, mounting to an OEM Flange.
    This is just one configuration out of multiple.
    I took the ball and ran with it. Likely to far.
    Even though i have the dual O-ring set up flange blah blah blah.
    No leaks for me.
    Lots of pain in the cleaning, when i need to reinstall it though.
Name:	High Temp Silicone.jpg
    Slidell, LA
    4,738
    Its a mess and if you have a good ring/gasket on the flange then you will have enough for an adequate seal.
    I would be a rich man if I charged the time it takes for me to remove all the RTV someone used when trying to seal up a pipe.
    May 2015
    Liberty, Ky
    232
    With care i will post my reasoning for using High temp silicone
    No leaks for me.
    If I have any leaks, I may go that route. But I doubt I will need to.
    Everything fits nice and snug, plus new exhaust gasket and new springs oughta make it seal.
    Either Friday or Saturday I'll have a status report on how hooking everything up is going.
    Oh, Yaeger, where was I suppose to spray the starter fluid to check for any air leaks?
    Spraying around the intake boot obviously, I thought there was somewhere else aswell.
    Thanks fellas
    Slidell, LA
    4,738
    around the reed cage (where it bolts to the head) and around both bell housings of carbs will suffice. Do you have the equipment to do a pressure test by chance? Also a good course of action for that motor.
    May 2015
    Liberty, Ky
    232
    No, I dont.
    Motor is strong, starts within 3 kicks.
    I wouldnt expect it to have any leaks with as well as it runs and with as well as is appears to be sealed.
    I can get a tester from Oreileys.
    Just have to plug both intake and exhaust ports correct?
    Side note, I bought this bike since my Dad is coming with me this year and is stealing my (technically his) 200X for the trip. Id prefer it not blowing up on me during TF.
    ALSO, 32:1 decent spot for these bikes or shall I bump up the oil?
    Slidell, LA
    4,738
    Plug for exhaust only. 1-3/4 should work but measure before you go buy the expandable plug. Intake is a little more challenging. I use a piece of delrin BkM turned down so it would fit snug in my intake. Then I drilled a hole through the delrin and screwed in a dragons tooth fitting. All you have to do after that is run a line from the fitting to a pressure gauge and you are good to go. I can email you pics of mine if you want to see how I set it up.
    averysdad is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jan 2013
    Cleveland, tx
    218
    I used a pipe I had laying around the house made up the difference with electrical tape Click image for larger version.
ID:	232349Click image for larger version.
    $5 gage from lows and Click image for larger version.
