Results 46 to 60 of 62
Thread: Mounting tires manually
  1. #46
    Queef Chief's Avatar
    Queef Chief is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2015
    Rineyville, KY
    231
    This thread is not the least bit tiresome, but maybe I'm being bias.
  2. #47
    Aug 2015
    Idaho
    842
    Quote Originally Posted by tripledog View Post
    Keep clear of the bead when seating a new tire. You could dunlop off a finger.
    If your runnin dunlop, you've done been lapped. Hoosier daddy!
  3. #48
    May 2012
    Waukesha, WI
    66
    I know you guys are talking about saving money and all, but as mentioned earlier a good set of tire bars goes a long long way.
    As far as breaking the bead goes, we bought this tool a few years ago and it is amazing. http://www.northerntool.com/shop/too...2827_200322827
    I have changed tires on several ATV's, lawnmowers, hay wagon and tractor tires filled with calcium chloride that has not been off the rim in 50 years and this tool made short work of breaking the bead. Just spray a little PB Blaster or really soapy water around the bead and boom, you will have that bead broken in less than 5 min.
  4. #49
    tripledog's Avatar
    Aug 2011
    Central New York
    2,182
    Thanks for the link, fixer2u. I have to replace the rear tires on my 1945 Farmall M, and now I have an excuse to buy another tool. I would likely have to pay someone more to change my tires than the cost of the bead breaker, not to mention that I have many other tires to change.
  5. #50
    Mexico
    9,018
    No posts for over 5 hours? It was starting to look like this thread had lost traction.
    It sucks to get old
  6. #51
    Jul 2013
    USA
    737
    In a rut......
  7. #52
    tripledog's Avatar
    Aug 2011
    Central New York
    2,182
    You're not michelin much.
  8. #53
    Mexico
    9,018
    It's been a good year for joking around on here.
    It sucks to get old
  9. #54
    Aug 2015
    Idaho
    842
    Road block. Buckle up for another screeching halt.
  10. #55
    Aug 2015
    Idaho
    842
    Wait. Where'd it go. That sounded fishy trip. Must have been a detour
    To answer your question "kenda 200s forks fit on a 200es?" Don't think so...but I could be wrong again
  11. #56
    Jul 2013
    USA
    737
    Tubeular dude. Bounce
  12. #57
    tripledog's Avatar
    Aug 2011
    Central New York
    2,182
    Quote Originally Posted by Jd110 View Post
    I removed the comment. After reading post #54, I thought perhaps you found it offensive.
  13. #58
    Aug 2015
    Idaho
    842
    Sounds like a detour down a bumpy road. I find as I get older I choose smooth sailing. Hope you have fun with your kind spirited comments. Peace to you, good buddy
  14. #59
    TTown, Alabama, United States
    845
    Yeah you guys keep me rolling
    Suicide Hill Survivor
    The rides:
    1981 ATC110
    1982 ATC185
    1983 ATC185s
    1984 ATC200es
    1985 ATC200x
    When the going gets tough, the tough get sideways
  15. #60
    Austin, Massachusetts
    1,591
    timing on this thread coincided with a Big Red refresh, including new skins, so i figured id show off my tire changer. Click image for larger version.
ID:	232617Click image for larger version.
ID:	232618Click image for larger version.
ID:	232619Click image for larger version.
    Its a few pieces, but it works the nuts, and you can make one fairly easy. Its pipe and square stock. A little welding.
ID:	232621Click image for larger version.
ID:	232622Click image for larger version.
ID:	232623Click image for larger version.
    A little lube, and she pops right off. I pulled all three (two ancient wooly boogs and a newer Deestone) in about twenty minutes
ID:	232625Click image for larger version.
ID:	232626Click image for larger version.
ID:	232627Click image for larger version.
ID:	232628Click image for larger version.
    Wubba Lubba Dub Dub!!!!!
    TRIKES:
    86 250r
    85 250sx
    86 250sx
    85 Yama 225DX - The Rental!
    150cc Piranha powered 70
    110cc Lifan 70
    82 70
    83 ALT 50 Trail Buddy
    88 Yamaha BW 80
    84 z50
