Results 1 to 4 of 4
Thread: Honda fl250 oddysey question/help
    Sep 2014
    British columbia
    7
    Hello all ..
    Just pick up a 84 fl250 in amazing shape..
    The only problem I have is the lights up front and the rear tail lights..
    I am in desperate need of a good guide to help walk me through the possible problems and help me figure out what wires are what ..
    Jun 2009
    Leander TX
    2,217
    It's been 30 years since I last worked on one...
    These guys have been great in the past: http://pilotodyssey.com/
    I'm sure some folks on here have knowledge to share, too.
    Jun 2009
    Leander TX
    2,217
    Assuming it's wired like an old hardtail ATC...
    Yellow is light power from stator to light switch.
    Green is ground.
    Blue is high beam from switch to headlight.
    White is low beam from switch to headlight.
    Brown is tail light.
    You can check for AC voltage (yes AC) at the lights with a mulimeter - black wire in green plug, red in blue white or brown depending on what your checking (with the engine running).
    If you have voltage, you just need new bulbs. Generally if one burns out, the other bulb fails shortly after.
    If no voltage, check the yellow wire coming out of the stator for AC voltage. If no power, the the lighting coil is bad. If yes power, you have a connection, wiring, or switch problem.
    Did the red FL250s have a connector to allow removing the cage?
    How about some pics?
    I have a soft spot for the original Odysseys - we had 2 growing up - our first ATV was a 79 my dad brought home in the back of our Chevelle wagon!
    RUNMEDOWN is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2006
    Omaha Nebraska
    321
ID:	232633 this may help
    85 ATC110 - The Greatest ATC of all time - (My First - new in 85)
    83 FL250 - Odyssey w/420cc - SOLD
    82 185s -10.25:1 piston, Full 200x upper, Goki Electric start - SOLD
    84 200x - Auto-X - Weisco Hi-comp, Cam'd, Bassani'd, Westcoast swinger, -SOLD
    82 200E Big Red -SOLD
    85 ATC250ES Big Red - Snow Plow !
