Thread: Problem with my 200
    Problem with my 200
    Ive got a 1983 honda 200 and my needle was in bad shape and my carb was leaking so i bought a good used carb that was on a running trike.I put it on mine and set up the air screw and it ran fine and then one day it started running bad so i put a new plug in it and it just kept getting worse.at first it would run and then when it got hot or after 5-10mins of running it would choke and then die and now as soon as i start it up it idles sky high and then shuts off...any ideas?
    nitekrawler is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2003
    430
    I would take the bottom part of the carb apart and spray it with carb cleaner. If that doesn't work, sounds like a bad float or needle.
    1982 Honda Atc 250r - Daughter's
    1982 Honda Atc 250r - Son's
    http://forums.atvconnection.com/photos.cfm/ID/1566/#TOP
    Anyone? I was thinking it might be the fuel shut off valve because when I had the tank off I could turn the gas on and it was very slow to come out.Would it be the coil?
    Shrewsbury, West Virginia
    564
    Quote Originally Posted by smokinp
    Sounds like your petcock is clogged, starving the motor from gas.
    Justin ~hondaATCman~
    '82 Honda ATC 110
    '81 Honda ATC 250r (Summer Project)
    '87 Suzuki LT 250r Quadracer - Very Modded...FAST!!
    '03 Yamaha Big Bear 400 4x4
    '85 Ford Bronco II 4x4 2.8 V6
    Jul 2003
    430
    On both my daughters and son's new atc, we replaced the coil wire and boot w/plug 8)
    I know this sounds weird but i blew the carb clean with some carb cleaner and an air compressor . I changed the fuel filter that comes from the tankl to the carb and then put a new needle. Fixed my carb problems
    Vic
    "We wouldn't be Anything without Gravity"
