85r motor swap question
So I wanted to give my 85r it's time to shine, I just finished up a motor swap taking my 86 trx 250r motor carb setup and putting it on my 85 atc 250r. They both ran good before the swapping but my trx is a really fresh motor from BDT racing. The 86 trx had a 38mm keihin and my 85r is still on its stock round slide. Both have full fmf systems. When I got my trike finished I took it for its test ride and something just isn't quite right. It's idling kinda high and stuttering showing a lean symptoms (I believe). I just wanted to make sure the electronics are not different causing my problem before I begin attempting any jetting. I did a short ride so I would not do any damage if the electronics are the problem. And everything plug up the same so I did no custom anything.
Any help would be great because if I need to do a swap back before trike fest comes as it's fast approaching and I don't want to leave number 27 at home!
And no I haven't put my trx back with the 85 motor I wanted to see how it went before it got put back together
One of the Haspin Locals
Trikefest 12' 13' 14' 15' 16' 17'
Trikes owned
1985 Honda atc 250r - raced by yours truly #27
1985 Honda atc 250es big red- Dad bought new from Ike's Honda in Richmond Indiana
1984 Honda atc 200s - raced by Evan Pflum #3
