Page 3 of 3 FirstFirst 1 2 3
Results 31 to 33 of 33
Thread: 85r motor swap question
  1. #31
    Slidell, LA
    4,738
    Quote Originally Posted by trikeguy2014 View Post
    I put a few hours on my trx just taking it real easy, probably more than I needed, but I wanted to take the extra precaution on it. I had 2 trips to haspin, several rides around the house and farm on the trx after the break in, I'm guessing around 8 hours of actual hard riding on it. It ran great, no leaks no problems out of it till the swap. Like I said I'll post back after it gets pulled apart. I did get swapped back and we should be good to go for trikefest, least I hope
    So the trx won't kick over now? This is a motor from BDT?? What was done to this motor? Holy shite man, issues galore. How does a trx motor with only 8 hours crap out that fast. Get your money back or you didn't break it in properly.....something isn't adding up.
  2. #32
    trikeguy2014's Avatar
    trikeguy2014 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2014
    Indiana
    158
    It started to seize up, I'll post back when I find out more, I don't think it was there fault, I think I know what happend but I want to be sure before I jump to conclusions. It will be after trikefest sometime.
    One of the Haspin Locals
    Trikefest 12' 13' 14' 15' 16' 17'
    Trikes owned
    1985 Honda atc 250r - raced by yours truly #27
    1985 Honda atc 250es big red- Dad bought new from Ike's Honda in Richmond Indiana
    1984 Honda atc 200s - raced by Evan Pflum #3
  3. #33
    Blossvale NY
    4,563
    Every good builder stands behind their work if the failure was a shortcoming or mistake on their end. Not saying anything bad about BDT specifically here, but mistakes do happen and they can happen with anyone.
    I still cannot think of a single reason swapping the mill into your ATC would be detrimental other than some oversight on your part and it seems as though you covered your bases. At this point I am thinking it is an incredible coincidence that something let go after the swap.
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
