Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 33
Thread: 85r motor swap question
    trikeguy2014's Avatar
    trikeguy2014 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2014
    Indiana
    158
    So I wanted to give my 85r it's time to shine, I just finished up a motor swap taking my 86 trx 250r motor carb setup and putting it on my 85 atc 250r. They both ran good before the swapping but my trx is a really fresh motor from BDT racing. The 86 trx had a 38mm keihin and my 85r is still on its stock round slide. Both have full fmf systems. When I got my trike finished I took it for its test ride and something just isn't quite right. It's idling kinda high and stuttering showing a lean symptoms (I believe). I just wanted to make sure the electronics are not different causing my problem before I begin attempting any jetting. I did a short ride so I would not do any damage if the electronics are the problem. And everything plug up the same so I did no custom anything.
    Any help would be great because if I need to do a swap back before trike fest comes as it's fast approaching and I don't want to leave number 27 at home!
    And no I haven't put my trx back with the 85 motor I wanted to see how it went before it got put back together
    One of the Haspin Locals
    Trikefest 12' 13' 14' 15' 16' 17'
    Trikes owned
    1985 Honda atc 250r - raced by yours truly #27
    1985 Honda atc 250es big red- Dad bought new from Ike's Honda in Richmond Indiana
    1984 Honda atc 200s - raced by Evan Pflum #3
    Kentucky
    2,294
    Intake boot in good shape ? Any cracks that could cause a small air leak ?
    Tionesta Trikes ATC 450R
    86 250R
    86 Tecate-3
    83 ATC 70
    85 Big Red
    81 KLT 200
    85 250SX
    devore,ca
    1,045
    I'm running a BDT trx motor in my 85R. There was no change in the electronics. I think you have something else going on.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
    Slidell, LA
    4,738
    Stuttering where? On idle? If not, what throttle position? Need specifics on what's exactly going on.
    Mar 2014
    Indiana
    158
    Yeah intake boots everything is in good shape, I'll give it a good once over again and make sure. Could it just be running a tad lean from being a different pipe and intake boot etc?
    Trikes owned
    Slidell, LA
    4,738
    It could be running lean for multiple reasons. Intake leak, failed seals, wrong jets. I would spray carb cleaner over intake joints while it's running to see if it dies. The I would do a pressure test. What jets in carb? Any port work, head work? Different reeds?
    Mar 2014
    Indiana
    158
    High idle some stuttering from about half on to full throttle... Engine ran perfect when it was in my trx, I just pulled it out and did the swap. I just wanted to be sure it wasn't anything electrically different that would cause it the problem
    Trikes owned
    Mar 2014
    Indiana
    158
    Reed assembly and carb throttle and cable everything came off straight from my trx.
    Trikes owned
    Slidell, LA
    4,738
    Have you checked for intake leaks and/or pressure tested the motor?
    Mar 2014
    Indiana
    158
    I'll spray some carb cleaner around all the intake joints and see if it dies or not.
    Trikes owned
    Slidell, LA
    4,738
    So essentially you put an 86 trx motor and 38 mm carb on your 85 250r? it was running perfect in the trx? What airbox were you using on the trx vs now on the ATC?
    Mar 2014
    Indiana
    158
    Yeah that's all I did, both setups were on air boxes with lids and full fmf systems. The engine carb reeds was all from my trx
    Trikes owned
    Slidell, LA
    4,738
    All things being equal; if it was running good before it should be running good now. Double check intake leaks, and electrical comnections.
    Mar 2014
    Indiana
    158
    Still no luck looks like this wknd I'll be switching back to my 85 motor, I still believe it's something electrically, jetting can't be that far off. I'm having eratic idle, doesn't die but sometimes idles high sometimes it's fine. also it just stutters a lean sound and just doesn't have much power. I don't know what else to do.
    Trikes owned
    Carthage NY 250r rules
    2,355
    Try putting the trx coil on the atc.
    250r rules
