Results 1 to 11 of 11
Thread: 350X Head Temperature Range???
    MN250R's Avatar
    MN250R is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2003
    Minnesota
    285
    Anyone know what a safe temperature is for a good running ATC 350x?
    I have an 86 and am installing a trail tech head temp guage on, and was just curious what they should be running for temp.
    Thanks!
    1986 ATC 350X
    1986 ATC Big Red 250ES
    Mar 2007
    Texas
    5,045
    it will vary greatly on an air cooled motor. it will range from 170-250 depending on how hard and how long you push it. temps in the 300's is not good. that typically means your running lean.
    ________________
    https://www.mikesatvfix.com
    MN250R's Avatar
    Jun 2003
    Minnesota
    285
    Awesome Thanks!
    1986 ATC 350X
    devore,ca
    1,017
    Report back with what you readings you get.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
    Sarnia, Ontario, Canada
    3,415
    Seems a bit pointless to me..just for the reason that head temp will vary so dramatically with load, speed and ambient temperature. A liquid cooled engine I could see such an exercise.
    If its combustion chamber temp you are concerned with as you're trying to work out carb jetting then an old fashion plug tip read would be more accurate. If you're plug comes out white then beware..you're gonna burn your piston or valves.
    But if you're just a gauge geek..I'd consider seeing if you can fashion up an oil temp gauge in line to the cooler. That could be more useful information than head temp.
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    MN250R's Avatar
    Jun 2003
    Minnesota
    285
    Well, I went riding today with a friend on his banshee. Temperature was 82 degrees out. Temperature varied from 400-450 on the gauge for head temperature after running for a while. This is completely stock motor, stock exhaust, brand NOS 86 350x carb, factory jetting, new air cleaner with lid on. Ran awesome all day! I checked the plug and it was tan.
    They definitely run hotter than liquid engines.
    1986 ATC 350X
    Oct 2007
    Grosse Tete, LA
    3,440
    What oil are you running? Something isn't right.
    My money is on your sensor pulling an incorrect reading.
    Anything that high and your valve seals are going to take a dump.
    Buy a cheap IR thermometer and shoot the head.
    My money is your sensor is reading exhaust temp.
    I have run a 300 honda up to 350+ while spraying, it started blowing light smoke as the valve seals failed from heat. With an oil cooler installed my oil temps stay right around 195 degrees. That's running gn4 10w40. It falls a bit more when running full syn motul.
    MN250R's Avatar
    Jun 2003
    Minnesota
    285
    Im running Valvoline atv oil 10w-40. Im gonna use rotella T next. My head temperature probe goes under the spark plug. That's possibly why its so high of a reading? I will use my IR thermometer on my next ride here in a couple days. Do you have an oil temp gauge installed?
    Quote Originally Posted by The Goat View Post
    1986 ATC 350X
    Wichita, Kansas
    1,361
    You could also test your sensor, toss it into the oven and read the gauge. Then double check the oven's accuracy with a thermometer next to the sensor.
    If your into gauges, I'd grab an oil temp as well as an egt sensor+probe. Those exhaust temps will tell you that your over heating pretty dang fast. Ask the diesel guys or turbo guys about them.
    Mar 2007
    Texas
    5,045
    I would think your running lean.
    ________________
    Oct 2013
    Wherever I May Roam
    3,757
    Quote Originally Posted by dougspcs View Post
    Head temp is a very valid and useful reading for monitering the health and efficiency of an air cooled engine.
    What you are measuring under the plug is combustion chamber temp. The optimum values for this test will differ greatly from the optimum values for a head temp test. I can explain further if necessary.
