Last year I had the frame, handlebars and other various parts of my KLT160 powder coated. Since then the start/stop switch does not work nor do the lights. It also gives me the occasional jolt up at the switch housing. Tried a different switch housing with same results (no shut off and still getting jolts). Trike will start but gotta stall it or pull plug wire to shut off. Other than the switch on the handlebar the only other ground point I see is at the coil. Do I need to take the powder coat off where the coil bracket contacts the frame? What about on the handle bar? Why does it effect the lights?Electrical illiterate here so be nice.
