Results 1 to 15 of 15
Thread: 200x gearing
    May 2016
    blossvale n.y
    102
    200x gearing
    So whats everybody got for gears on there 200x . Im thinking 13/36 is what im gonna run for flat track . Any input appreciated
    May 2016
    blossvale n.y
    102
    Anybody know whays stock at least
    May 2016
    OH Canada
    1,102
    What year X?
    I am running stock gear on my 1983. 12/40
    May 2016
    blossvale n.y
    102
    Thanks .well im building a 185s flat tracker with an x motor on it . If 12/40 is stock i may be able to pull 13 /34 gears no problem .motor is being stroked and big bored .
    RUNMEDOWN is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2006
    Omaha Nebraska
    321
    11/30 w/18" rear rubber. (Still on shelf waitng for final assembly, hope it works in real world, works in Math world)
    85 ATC110 - The Greatest ATC of all time - (My First - new in 85)
    83 FL250 - Odyssey w/420cc - SOLD
    82 185s -10.25:1 piston, Full 200x upper, Goki Electric start - SOLD
    84 200x - Auto-X - Weisco Hi-comp, Cam'd, Bassani'd, Westcoast swinger, -SOLD
    82 200E Big Red -SOLD
    85 ATC250ES Big Red - Snow Plow !
    Carthage NY 250r rules
    2,355
    Where do you race flat track.Sounds like a cool build your doing.
    250r rules
    May 2016
    blossvale n.y
    102
    All private land trying to get more people involved and willing to participate
    2,355
    Paradise speedway in Geneva ny has three wheeler classes.200 and open.
    250r rules
    May 2016
    blossvale n.y
    102
    Whoa first i heard of this now im even more pumped to get it done should have 250r front end on and my new rims and extended hubs by the end of week .
    2,355
    We have a 6 race point series. We had # 4 race 6/18 next race for trikes is 8/24 then 9/3 .
    250r rules
    May 2016
    blossvale n.y
    102
    Well thanks for replys guys . Hope to race with you in september atc300r
    Oct 2013
    Wherever I May Roam
    3,757
    Very much depends on tire size. Gear ratios are calculated driven divided by drive. Stock gearing is 12/40. so 3.33:1. Numerically lower is a 'taller' gear, for example your proposed 13/36 is a 2.77:1 ratio. Stock rear tire size is 22", so if you are running shorter tires such as 18" for flat track, it will bring the final drive ratio back up numerically, resulting in 'shorter' or lower gearing overall. 13 is the largest front sprocket that will fit without contacting the case saver. I ran 14/35 gearing with 20" tires on my 229cc street trike and it would hit around 70mph with only 4 forward gears. Gearing is part of the race tuning process. It's easiest to have a few different front sprocket sizes to quickly change and evaluate.
    May 2016
    blossvale n.y
    102
    I totally agree just wanted a good base point with the rear and make changes with the front to tune.
    Slidell, LA
    4,738
    I ran 13/36 with 16" hoosier cross blocks on my flat track bike. It would pull like a freight train for a 200x.
    May 2016
    blossvale n.y
    102
    Exactley what im running for rubber as well thank you
