KX100 trike in action
Road it. Have vid on friends phone, upload later tonight or tomorrow. Need to adjust gearing a little yet. Does most things well.
https://www.youtube.com/watch?v=R996...ature=youtu.be
Added vid. Just need to tinker with gearing yet some.
Wow, that's pretty impressive for its displacement and considering its a lot heavier now. Does it suck for slower paced stuff? I know my 82 rm has like no bottom end and that was a 125 even.
Right now the low end is a little doggy. I need to down down a tooth in the front for sure and see if I can get more spin action out of rear. I out ran my friends canam renegade 500 on it. He tops out at 50mph. I want more low end then topend for this bike. Remember this is an Eric Gorr topend (porting and redomed head really make a difference)
Have you considered trying some smaller sized tires? My KTM 125 could not pull 18 inch tires but with the 16 inch RAs it was awesome.
Those razor tires are ultimate traction. The only place I like them is at the dunes. Everywhere else they have too much bite.
18 is as small as i want to go for trails. I got a 11T front sprocket to see if that helps. the KX dirtbike has a gear ratio 4.15 of and right now I am not even close to what a 200x was stock 3.33. it was a guess and i am currently at 3.17 so with 11T front and 38T rear I will see 3.45 I think the sweet spot will be around 11T front and 40T rear for 3.64 gear ratio
I do not have razr tires on the back but something similar. I was toying with turf tramer also but I just need a little more low end.
//ArrowChat Integreation Code
