Thread: goki starter for Honda 350X
    fxrs is offline New to the board Arm chair racerNew to the board
    Sep 2011
    marana az
    39
    Can anyone tell me what starter fit a goki starter kit for a Honda 350X. Mines broke and there are no markings on it.It looks like a seedoo starter but thats bout all I can tell. Goki doesn't seem to be in buisness now.Help please
    devore,ca
    1,056
    I'm in the exact same boat. I sheared the shaft on mine. Someone should have ended up with the inventory from Goki. The do look like starters for a small outboard motor though.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
    Mar 2013
    Central PA
    2,362
    Well this is all news to me. I didn't know they went out of business. Try last known contacts, might be able to dig up some info whether it's who ended up with the inventory like bob said, or where they sourced the parts.
    RUNMEDOWN is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2006
    Omaha Nebraska
    321
    Get some measurements off the input shaft and such, I will check a few of mine to see if they match up to anything. I have a Goki for an FL250 and an atc 185s and the electric motors are identical, same as the Goki snowmobile starters. But I have never had an ATC 350x kit to compare it too.
    85 ATC110 - The Greatest ATC of all time - (My First - new in 85)
    83 FL250 - Odyssey w/420cc - SOLD
    82 185s -10.25:1 piston, Full 200x upper, Goki Electric start - SOLD
    84 200x - Auto-X - Weisco Hi-comp, Cam'd, Bassani'd, Westcoast swinger, -SOLD
    82 200E Big Red -SOLD
    85 ATC250ES Big Red - Snow Plow !
    Sep 2011
    marana az
    39
    starter lenghth7 1/2" ,dia. 3",9 splines,9 teeth on starter gear,12 volt, ccw rotation,bolt holes 8 mm.hope that helps
    Sep 2011
    marana az
    39
ID:	232833Click image for larger version.
ID:	232834Click image for larger version.
ID:	232835Click image for larger version.
ID:	232836Click image for larger version.
    pics of starter
