Thread: Honda 200 aftermarket piston help
    Jun 2016
    chetek, wi
    4
    Hello everyone, I'm sure this has been asked many times so if there is a thread about it already please send me a link.
    Otherwise, I purchased a 65.5 wiseco piston and rings for my Honda 200, and had it bored to clean everything up.
    But when I read the ship manual for the bike it says on the top of the piston is "in" and that is the side on the piston for the intake. Well on the wiseco piston it just has an arrow on top. Now after pondering it for a while I looked at the valve reliefs in the top of the piston and the intake valve is larger then the exhaust valve so I used the diameter of the valve reliefs in the piston to determine what direct to install the piston. Which put the arrow facing the exhaust valve. My question is is that correct? Because now when it's running there is a nocking sound every time it fires.
    Thanks!
    Slidell, LA
    4,738
    Arrow points toward exhaust pipe.
    RUNMEDOWN is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2006
    Omaha Nebraska
    321
    yes, arrow goes out, think of it as a representation of flow.
    85 ATC110 - The Greatest ATC of all time - (My First - new in 85)
    83 FL250 - Odyssey w/420cc - SOLD
    82 185s -10.25:1 piston, Full 200x upper, Goki Electric start - SOLD
    84 200x - Auto-X - Weisco Hi-comp, Cam'd, Bassani'd, Westcoast swinger, -SOLD
    82 200E Big Red -SOLD
    85 ATC250ES Big Red - Snow Plow !
    Leevvii's Avatar
    Leevvii is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2016
    Australia
    216
    Thats never usually a good sign, i'd check it out. Though knocking is a difficult word to define with engines, id get a trained ear to take a listen.
    Jun 2016
    chetek, wi
    4
    Thanks for the quick turnaround!
    So cense the piston in in correctly, what could be some other culprits for the nocking? I have trying adjusting the rockers, and that doesn't seem to help.
    Leevvii's Avatar
    Mar 2016
    Australia
    216
    Big end bearing will do it, low octane gas can do it, worn exhaust flange[more of a pop though], crank bearings??, leaking valve, Cam slap from worn cam bushing/thrust washer. The cdi makes a sort of ticking noise [is normal] Im only 1/2 a mechanic, plenty of pro's here though.
    Leevvii's Avatar
    Mar 2016
    Australia
    216
    which reminds me, i must post asking if the camshaft bush/bearing is available, i suspect mine is worn [off to the measuring dept we go LOL]
