Results 1 to 4 of 4
Thread: Help with honda atc 110 85 gear lever
    Aug 2010
    Bradford
    62
    Hi I have a honda atc 110 year 1985 and I'm in the UK. I was wondering if there's a gear change lever that is simular to the original I can use as mine stripped itself. As I'm in the UK there are rare a rocking horse . It would cost me a fortune to get one from America. So if anyone knows of another honda model which uses a simular gear change lever please let me know. Thank you
    arlaunch's Avatar
    arlaunch is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2014
    Oregon City
    346
    Crap!
    I am interested what the diameter of the spline shaft coming out of the engine is.
    If you have a dial caliper you could get that info.
    It would help.
    Maybe most of Honda shafts are the same? If so any one would work.
    Can you produce measurements?
    This is interesting!
    1984 Honda Big Red ATC 200ES (Emma)
    1985 Honda 200X ATC (Pretty Boy)
    1985 Honda 250R ATC (Dr. Fast)
    1985 Honda 250R ATC ( 77 )
    1985 Honda 250R ATC (Baller)
    1986 Honda 350X ATC (Go Go Girl)
    Feed Back: http://www.3wheelerworld.com/showthr...k-for-arlaunch
    sanchez's Avatar
    sanchez is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2009
    where ever i may roam
    228
    Most shifter shafts are the same size. Cut off bad, buy new spline, weld
    Appearing since '07
    Looking for a place to happen...
    Making stops, along the way
    Mackus84's Avatar
    Mackus84 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2016
    Lakeland, Fl
    427
    You could possibly even drill a hole though the shaft and shifter and use a small bolt through it all to hold it on. It would have to be small. Like an m3, thats just a guess though
