Results 1 to 14 of 14
Thread: Atc480r
    May 2008
    Juneau
    605
    Atc480r
    So I put an 83 cr480 engine into an 85 200x, it's coming along nicely, fresh motor rebuild,the extended swing arm is going on next, also gotta derust the exhaust, waiting on a parts from a 200x I had my buddy part out down in the states, it's hard to get parts in southeast Alaska
    3 wheelaholic
    ATC200/CR480 custom
    1984 atc250r near mint
    wr450f trike on the way
    Trizinger for my sons
    May 2015
    Watford city, North Dakota United States "THE BAKKEN" / Lebanon, Oregon United states.
    1,081
    Lemme know how that frame holds up with that power house
    Sent from my SM-G935V using Tapatalk
    Saying "it's the trikes fault" is like saying "guns kill people"
    don't poke the bear... you'll get banned
    May 2008
    Juneau
    605
    I built the frame, It'll hold up, half the frame is 480 and half is 200x also it's reinforced
    3 wheelaholic
    ATC200/CR480 custom
    NEPA
    7,051
    Gonna be way past a handfull. Looks like the stuff rusts up there as bad as it does down here!. 200X parts are fairly easy to come by,throw an add in the classifieds here if you find yourself needing anything. Good luck
    Nov 2014
    Chico,CA
    473
    My 83 CR480 trike suffered from extreme vibration and later we found out that model year suffered from poorly balanced cranks from the factory so if you ever have the motor apart you might wanna consider having the crank balanced if yours also vibrates badly.
    May 2008
    Juneau
    605
    Quote Originally Posted by John_Neary View Post
    That would have been nice to know when I had it apart, how fast was your trike? What chassis did you run? Have any pics?
    3 wheelaholic
    ATC200/CR480 custom
    May 2008
    Juneau
    605
    Quote Originally Posted by atc007 View Post
    I've been riding fast trikes my whole life and thwyre never enough, I always want more power my 84 250r is a blast that's why I wanted to stuff this air cooler in a lighter bike
    3 wheelaholic
    ATC200/CR480 custom
    Nov 2014
    Chico,CA
    473
    It used a custom 82 250R style frame made for us by Nick Nicholson. I raced it only a couple of times and it was quite the handful i gotta say. I do not have many good photos of it but here are a couple i found.
    It is the #10 bike on the trailer in the background.
    I tried racing it at a few times, both motocross and TT and found the 4 speed gearbox difficult to work with due to the ratios it had. On long straights when it would be tapped out in fourth my hands would just be a blur from the vibration.
    May 2008
    Juneau
    605
    That thing is awesome! I rode an 82r with a 300 kit and it was scary haha fat front tire is not the way to go, I believe mine is the 5speed gear box is it an 84 then?
    3 wheelaholic
    ATC200/CR480 custom
    Nov 2006
    southern oregon
    2,338
    No it's '83 if it's 5 spd. The 4 speeds were '82's. The '84's were 500's and they are right side kick & left side drive
    2-stroke lover
    Nov 2014
    Chico,CA
    473
    Mine must of had a 82 engine than, my mistake. The fat front tires are not as good for motocross but are better for flat track and TT, more contact patch is more traction.
    May 2008
    Juneau
    605
    Quote Originally Posted by cr480r View Post
    It's an 83 cr480 engine 5 speed, 90mm bore
    3 wheelaholic
    ATC200/CR480 custom
    May 2008
    Juneau
    605
    Got some new parts in
    Attached Thumbnails Attached Thumbnails 0725161804a.jpg   0726161954.jpg   0713161906.jpg
    3 wheelaholic
    ATC200/CR480 custom
    Willamstown PA
    5,824
    good luck with it. My built KX100 motor vibrates my hands good.
