As a big fan of LED's, your not going to find what your looking for. Anything worth while will either need to be modded, or custom made. The bulb you posted is for a tail light, not a head light.
Lumens and color temp are the 2 biggest factors. A quality standard halogen car headlight is about 900 lumens. HID can push upwards of about 3000 lumens for 35 watts of power. LEDs are about the same in inefficiency as the HID currently. More lumens=brighter. Color temp is the color of the light coming out. A light at 2500 lumens and a color temp of 4000k will be visibly brighter than a light at 3000 lumens and a color temp of 7500k. As the temp get's higher, the color gets more blue and the human eye can't see it as well. Sure, the lux meter can pick it up, but you can't!
Ok, now that is out of ther way, there are a few lights out there that are cheap and will work, but this goes straight back to the modding aspect. If you don't mind hacking some plastic things apart, then awesome! I've done some ridiculous things with LEDs... For instance, my LED light that draws over 12 amps at 3.7 volts. Measures in at 4400 lumens. It's smaller than a pop can
Or my LED spot light that had 900lumens off a single XML-t6 and light up buildings over a mile away.
Don't believe the adds that claim stupid high lumens. They are compulsive liars. You can look up the datasheet for any cree LED. It will tell you how many lumens their light makes and at what wattage. This is an example. I own a few, they are pretty awesome for the size, but get blistering hot. They put out maybe 1500 lumens. http://www.ebay.com/itm/SolarStorm-8...MAAOSwJcZWc6-y Note the battery pack, it's 8.4 volts. I haven't tested these at 12volts or anything else. They mount directly to the handle bars.
For the LED lights, you'll want to search for things in this order (brightest to well, not brightest)
Cree XHP 70
Cree XHP 50
SST90
XML u2 <-Next best bang for buck
XML t6 <- best bang for the buck by far
XP G5
Here is some more lights.
This is maybe 2k lumens: http://www.ebay.com/itm/US-SHIPPING-...MAAOSwwpdW78W4
