So lately the kickstarter keeps slipping through the gears. I looked on ebay and have found the new gear for around $60. If i want to replace the gear will i have to split the case or can i just take off the side panel?
Just the side cover only.
I would recommend to inspect the ratcheting gears first before buying. There is a plastic spacer peice in there that should wear before gears do.
Alright thats good. Sames me a lot of money.
13070:
GUIDE,KICK SPRING
762568 13070-1063 Ships within 5 to 6 business days $13.76 $12.93
I believe its plastic.
I was told by a member who I consider a guru's go to guy when it comes to Tecate/Yamaha Tri-Z that the number one problem with tecate Kickstart (or perhaps any kickstarter for that matter) is the person doing the kicking.
Not enough patience in making sure gears are engaged before committing to the down stroke.
Not condemning anybody,,, just passing info along. It solved my problem.
But, those plastic pieces do wear out,,,,
john
Mines got a nasty habit of feeling like it engages. But soon as you put a little extra force into it... OUCH lol
You can also read this:
http://www.3wheelerworld.com/showthr...ckstarter-gear
86 T3
84 T3
86 KX250
