I do not agree. Logic dictates if you can burn a hole into a piston you then you will significantly increase temps. I have experienced and witnessed this a few times. More than I would like. The whole engine will be hotter.
My guess is your lean ( doubt your doing a plug check correctly, no offense) and or air leak.
To properly check a your tune.
You need 2 new plugs.
Put in new plugs. Start and out around in with no more the 1/4 throttle used and ride for about 5 min. Take plug out. This shows you the pilot/idle jet circuit tune.
Install new plug. Start but take off to at least 1/2 throttle and run for 1/2 throttle non stop. You can even blip to WOT. Shut down by NOT idling or sowing engine speed. You want to kill it right off the bad at mid throttle. Take plug out and check. This shows your mail jet circuit.
I would venture to guess if no air leak, the idle is fine and your main is light tan. Not good. Needs to be dark tan. Your probably rich. Again this depends on you NOT having an air leak like the boot or reed gaskets or something.
