Results 1 to 15 of 15
Thread: 1985 ATC250R Fork Question
    Jun 2004
    Oregon
    1,784
    So I'm looking to rebuild my forks and was just wondering other than Ebay, are there any other websites that might have some of the parts id be looking for to accomplish this?
    My forks keep leaking oil and I cant figure out how to fix it. Tubes look pretty straight and I've replaced the upper seals and dust caps. Progressive springs as well!
    Other than that not real sure where to go from here. Any help would be great. Thank you
    1986 ATC 250R
    Ported w/ Cool head
    LED pipe and silencer.
    Vforce3
    Keihin PWK 38mm
    Works Ultra Cross Shock
    LSR +2 Axle
    American Star Racing +4 Swinger
    LED Intake
    Hi-Flite desert seat
    OEM clutch 89 upgrade
    2021 YFZ450Rse Rossier R5 Titanium Header AIS Delete FCI Vortex ECU
    Las Vegas, NV.
    2,531
    I would look into new bushings for your forks. If your bushings are worn, or the ID of your lower fork tubes are worn beyond limits, then new seals won't last very long. As far as where to look for them, I'd try OEM first, then All Balls I guess.
    Good looking R by the way!
    Jul 2012
    Joplin, MO
    597
    Bushings aren't available oem. Bushings from a cb650 work and are available oem. I can't remember what year.
    Sent from my MotoG3 using Tapatalk
    Aug 2015
    Huntsville,AL
    40
    The microfiche on Partzilla shows the bushings as being available. The back-up rings are also available, is that something that wears out and should be replaced?
    Fox250r, how do you like the progressive springs, I was thinking of upgrading mine too.
    Oct 2013
    Wherever I May Roam
    3,757
    Sometimes partzilla lists parts as available when they are actually not available. I'm not saying that's the case here, just something to note.
    Slidell, LA
    4,738
    Quote Originally Posted by Fox250R View Post
    You can get the seal kit aftermarket. As stated you will want to replace the bushings and sleeves. Bushings are still available for the ATC 250R.
    Bushing: 51414-463-003 BUSH, FORK PIPE
    Sleeve: 51415-463-003 SLEEVE, FORK PIPE
    Progressive springs are OK, a better replacement is to have Milner use his method to change the damping on your forks.
    Jun 2003
    englishtown NJ
    2,676
    guy I go to for most work, he said when I sold him a set of forks, that if customer wanted(to pay for), he could replace all the guts with cartridge type suspension, giving full adjustabilty, more performance and getting out of the old tech stuff. He could do this for most forks out there, some cases is a improvement and others is a total tranformation.
    Aug 2015
    Huntsville,AL
    40
    Which part on the microfiche is the sleeve you mentioned? Sleeve: 51415-463-003 SLEEVE, FORK PIPE
    Aug 2015
    Huntsville,AL
    40
    Not trying to hijack the Op's thread, but I'm having the same issue with a leaking seal and I wanted to fix everything while I'm doing it so I need the same info!
    Slidell, LA
    4,738
    Quote Originally Posted by Usmoneylover View Post
    See the sleeve on the bottom of part number 8? Not offered as a rebuildable part on the 250r but they use it on many other models. Also replace that when replace the bushings...as a set, your shocks will thank you.
    Aug 2015
    Huntsville,AL
    40
    So that part number you provided is the part I need to replace mine? Thanks a ton for that info!
    Slidell, LA
    4,738
    If you have 85-86 ATC 250r forks, Yes it is.
    Jun 2004
    Oregon
    1,784
    Thanks for the info!
    1986 ATC 250R
    Ported w/ Cool head
    Vforce3
    Keihin PWK 38mm
    LSR +2 Axle
    LED Intake
    O.C., Oregon
    921
    parts needed-
    Lower fork bushings 51415-463-003
    Upper bushing - 51414-463-003
    Back up ring - 51412-463-003
    Circlip - 51447-463-003
    Add in new seals and wipers and your good to go.....
    1978 ATC70 w/ Piranha 140cc
    2017 YZ 250x- Braap
    Jun 2009
    Leander TX
    2,217
    Any pits or nicks on the tubes?
