Results 1 to 15 of 16
Thread: 84 200es exhaust?
    Jul 2016
    Mississippi
    7
    84 200es exhaust?
    My old exhaust is shot and fixing to buy another. Im wanting an after market of somekind, any suggestions?
    Oct 2013
    Wherever I May Roam
    3,757
    Time machine?
    Seriously though, I thing DG is the only new system available.
    Jul 2016
    Mississippi
    7
    Ok, onlynones ive heard of is dg and cobra. Im not sure if cobra will fit mine or not. Ever used dg?
    Oct 2013
    Wherever I May Roam
    3,757
    Quote Originally Posted by Corey woodall View Post
    Yes, I have used DG several times. They are LOUD. If I were you I'd stick with a stock system and avoid the noise and jetting.
    Wichita, Kansas
    1,361
    I'm with DOHC on this one. Stock will last for ever and is quiet.
    The further away from stock you go, the more of a head you make. If you want to be loud, or gain an unnoticeable amount of power, an aftermarket pipe would do it.
    Jul 2016
    Mississippi
    7
    So if i was to go with dg id have to rejet it?
    Jul 2013
    USA
    737
    Yes, you would have to use a bigger main jet. The amount of noise you will create with the DG is ....outstanding.
    Jul 2016
    Mississippi
    7
    Where would i get the other jet?
    Jul 2013
    USA
    737
    I only replaced the main, didnt mess with the pilot, probably need to check it. Jets r us online. I think i am using over a 125 with dg & k&n. Been a while since. 86 200x.
    * My bad, disregard ......thought it was another x post!
    Oct 2013
    Wherever I May Roam
    3,757
    Your 200es has either a 98 or a 100 main jet. Buy one each of the next 3 sizes bigger.
    Jul 2016
    Mississippi
    7
    Any idea on prices? Ive never messed with any jets, new to that
    Blossvale NY
    4,563
    I buy most of my jets from Jetsrus.com. Most genuine Keihin jets there run about $7 each.
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    Blossvale NY
    4,563
    I recommend you read this thread being that you state you have never changed jets before. This will go through the "hows and whys" of carb jetting. You should have a pretty descent understanding once you get through it: http://www.3wheelerworld.com/showthr...Jetting-Theory
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    Jul 2016
    Mississippi
    7
    Awesome, thanks for the help ya'll. Another question, whats a good tire set up? Ive have the bear claws before and really liked them, just lookin for something with enough tread to get me out of a sticky situation if encountered with out having to dog it. Really only use it for hunting and fishing but just if it does happen any suggestions?
    Blossvale NY
    4,563
    I'm planning to get a set of ITP Mud Lites for the rear of my 200es soon. They are one of only a handful of manufacturers making 25" tires for 9" rims any more.
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
