Results 1 to 15 of 21
Thread: CDI Upgrade
    Feb 2014
    BC canada
    15
    CDI Upgrade
    well the old girl quit. no spark. after my rebuild it was awesome one pull and purred away. as time went on it wouldn't give spark then suddenly be completely fine. if i unplugged the cdi and plugged it in again the problem would be ok for awhile now thought nothing at all.
    i bought a new coil no dice, cleaned all the contacts in the headlight, nothing. if i bang the CDI around it'll sometimes work. i bought a new cdi off ebay that listed my year and atc 200 thinking it would work i bought it and of course it doesn't. my trike is a 1984 200ES big red. The connector for the new CDI is the same round one on my trike but when i plug it in the reverse light immediately comes on. I've been reading all morning on this site about changing the CDI out to the chinese versions with the square connector. I'm wondering how different the CDI is on the 200x 200s etc with the round connector is to the round connector on my 200es? I'm pretty sure this is the CDI i biought . I know understand the 84 es CDI is a year only deal. so the CDI ihave must be for an ealrier bike? Can i just cut and reverse a few wires and still use the more common 200 cdi with the round connector? seems simpler than changing all wires out for the square connector. also would save me from having to buy a square cdi and square male connector.
    Also another note the Pulse generator on my bike doesn't give a signal on my test light when cranking. DO it est this with the leads connected or disconnected? Seems the blue/yellow should give a voltage when turning over? wondering if I ground one lead and probe the blue/yellow or probe the blue/yellow and ground to the other lead? the continuity check is bang on so im pretty sure this is not the issue.
    Blossvale NY
    4,563
    Disclaimer: I do NOT know for sure, but I would think that CDI's with the same round connector from other 200cc ATCs of the same year should work... Again, speculation on my part and I would be willing to plug one in and try it for the cost of a used unit.... The 200s, 200m, and 1st gen 200x have basically the same engine as the 200e/es aside from bottom end differences with E-start and in the case of the ES, shaft drive.
    Aside from that, no luck just sourcing a good used 200es CDI??? That would be my first move if I were certain the CDI was failing.
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    Feb 2014
    BC canada
    15
    thats what i was thinking when i bought it. looked the same and was listed as a 82-84 200 as compatible engines. I can still find a bunch of these on ebay. but seems the 84 has a specific CDI for that year only yet guys have rewired in chinese units and just lose the no start if in reverse function. they must have different something, the reverse is certainly missing on the other models. probably 2 or so wires are in different positions. theres not much out there for good used cdi's new ones are $150+
    on a positive note i just had it running. plugged the chinese one in took it off. put the stocker back in after tapping on the ground. first pull started right up. then i drove it 4 feet, put it in reverse and it died and then no spark again. I bet the reverse circuit in this CDI is part of its issue.
    Blossvale NY
    4,563
    Hmm.... I wasn't aware that the "no start in gear" circuit involved the CDI. But I suppose it would be a good idea with an E-start machine that has some type of manual backup starting method. I've never actually tried to start my 200es while in gear with the pull start...
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    Feb 2014
    BC canada
    15
    Ok so here's my question then. How is the 1 year only1984 200es CDI different then all the other round plug CDI's that are available for the other bikes and how do I know if I switch to the square plug type that it will work with my bike If it's supposed to specific to my bike? Is it just the reverse thing and that's it? If this is the only difference then the round pug CDI I got from ebay should work. I removed the reverse pin from that cdi and the reverse light went out and elec start is working again but still no spark. The old CDI works sometimes.. Bike runs great when it does.
    Jul 2016
    Penn run, pa United states
    50
    Not much experience with CDI boxes but when I was swapping different types (5 or 6 pin) on my scooter they all worked the same as long as the wires went accordingly.
    6,797
    Not sure if you know but the 84 200es CDI is still available new from Honda , I just bought one for a customer .
    Blossvale NY
    4,563
    Sorry GTP091, but you're asking questions that I am just not qualified to answer.
    I'll step aside and let others with more experience in this area take over. Looking to learn a little here myself.
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    Oct 2013
    Wherever I May Roam
    3,757
    Quote Originally Posted by GTP091 View Post
    Install a wire that connects to a ground to the pin that you removed the reverse circuit from on the CDI. Test and report back.
    Jul 2016
    50
    You said when you put it in reverse it died so I'd lean more towards you reverse switch as the problems since it as to be grounding out or not grounding
    Feb 2014
    BC canada
    15
    well if it's less than 80 cdn ill go for it.. the old one is 30 years old so not a bad run. id hate to pay the same to switch to the chinese typoe just to end up haing it not work as good as oem.
    the reverse circuit is fine on my trike. im certain thats not the issue. also it only affects the cdi when starting by elec start.
    Oct 2013
    Wherever I May Roam
    3,757
    Feb 2014
    BC canada
    15
    Well I'm willing to try anything. I take you mean when the original cdi is installed? Must be as the new cdi has no pin so wouldn't be useful even to do this. The reverse circuit works as it should I tested it and the light comes on correctly when in reverse. I'll give it a whirl and let you know the details. I'll ground the wire from the head light connection. This is where it goes to and then onto the light.
    Feb 2014
    BC canada
    15
    Well now I feel stupid.By removing the pin I destoyed a perfectly good CDI. Now ill never know if it wouldve been useable.. it was only 20 bucks, case of beer ill never enjoy.
    I opened the headlight and opened the reverse indicator circuit. Used my test light to ground it on and hit the starter button, nothing. Put it on the other grey lead and bamm 2 turns of starter and she fired rightup. Now it wont stop getting spark so I cant dig into the issue. At least im on the right track. Dohcbikes please tell me what you were thinking. From what I an tell by the wiring diagram on this trike the grey wire is the ground for the CDI? It goes to the inhibitor relay and seems a rather important cicuit for spark. Maybe the fault is in the reverse switch then?
    Oct 2013
    Wherever I May Roam
    3,757
    No I meant the cdi you bought. It needed a ground to that pin to operate. The wiring that goes to your reverse light comes from the reverse safety switch which is a ground circuit. They are prone to intermittent operation. By directly connecting a ground to the pin you removed, it will eliminate the switch circuit as a culprit. I highly doubt you ruined your CDI. Post a pic of the new cdi where the plug connects.
