I have an 84 200x the old motor was having problems so I found a brand new lifan motor for cheap. Anyway I see a lot of post on here a while back and just wondering how anybody set up there carb, when I start mine it idles perfect but when you Crack the throttle fast it just bogs. It does drive but has no power like it's running lean. Spark plug is consistently white. No mods on it either
Also I see that the carb is set up for an accelerator pump that I can't use due to the frame rail. From what I see about newer bikes this is the problem they have when there pump goes
