Thread: I have problems whit my honda 1984 atc 250r
    Jul 2016
    san diego
    HELLO FRIENDS , I HAVE A PROBLEM WITH MY MOTOR 1984 250R ATC HONDA , rebuilt OF THE TOP piston brand new rings , new spark plug , new packaging , put 32 : 1 mixture , and I have a muffler custom check if I have spark and have , turn to the first kick without problems , the problem is that I do not get the optimum , you sound like garbage revolutions , clean the carburetor, everything seems fine , and made ​​a small ride and does not run well ,tengo chispa, tengo mix gasolina nueva,tengo bujia nueva , tengo compresion en el piston ,tengo el carburador limpio ,que esta mal , ayuda por favor?
    i put the engien on cr500 frame กก i hope you like itClick image for larger version.
ID:	233292Click image for larger version.
    Blossvale NY
    4,563
    Hello and welcome to 3ww.
    It's difficult to understand the specific problem you are experiencing (no offense) but it sounds like you may have a jetting issue you need to dial in.
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    efhondakid's Avatar
    efhondakid is offline At The Back Of The Pack Arm chair racerFirst time rider
    Feb 2015
    Canton Ohio
    203
    Also 32:1 is very rich on the fuel mixture. I run 44:1 in my 85 R and it will still load up and foul a plug every once and a while.
    Blossvale NY
    4,563
    Quote Originally Posted by efhondakid View Post
    Another topic all together, but you don't have a fuel/oil ratio issue, you have a jetting issue. You can run em at 20:1 if you dial in the jetting accordingly.
    And in all actuality, 32:1 is probably the #1 most recommended ratio by the best 250r builders for most applications.
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
