Page 2 of 2 FirstFirst 1 2
Results 16 to 26 of 26
Thread: DEBATE: Are quad tyres OK to use as FRONT trike tyres???
    Leevvii's Avatar
    Leevvii is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2016
    Australia
    216
    Duder.....buy some tires
    Seriously, you "replace it" types!!
    Yeah, i kinda resided myself to it all along, just thought i'd ask if repair was possible, sometimes it pays to ask.
    I want to buy tyres, but "trike" tyres are not very available in Australia, not locally or readily at least. I've already spent as much on postage from the US, as i have in parts for my 200X restoration, its the same problems with sourcing parts in OZ.
    Im gonna be mainly riding dirt [bush] tracks, and the odd bit of sand if i can find anywhere locally that one is allowed to ride in these parts [ you greenies!!], So i would definately prefer the more rounded contour, as i believe flatter profiles would tend to allow more "lateral slide" style of riding, they would be OK on flat track and smooth surfaces [where drifting is a good thing], but our local bush is pretty rough on the suspension, so the reactive steering would be better IMO.
    Aug 2015
    Idaho
    855
    Comparatively speaking, 3-wheelers are a "green" vehicle. Especially if you get the camo type, with electric motor and stickers all over it. Fill your tyres with helium and you'll practically float.
    Blossvale NY
    4,563
    I run Kenda Front Max on 2 of my 3 sport/race trikes. I have found it to be an excellent front tire... And they are remarkably cheap compared to the more popular tires out there... And I will be setting up that last sport trike of mine with one when it's time to replace what's on it...
    http://www.tmsparts.com/4050501c-k28...FUIfhgodgeQEfQ
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    Leevvii's Avatar
    Mar 2016
    Australia
    216
    Yeah, nice rubber, i'll check them out locally also. thanks
    Leevvii's Avatar
    Mar 2016
    Australia
    216
    Just curious, what do the tyre dimensions stand for, im guessing
    O.Diam. X width X Rim Diam ?????????????????
    Blossvale NY
    4,563
    Height, width, and rim size, respectively....in inches
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    Leevvii's Avatar
    Mar 2016
    Australia
    216
    got it. Does amazon ship to Aust, or is it USA only?
    Blossvale NY
    4,563
    Not sure on that.. But as big as Amazon is, I would be surprised if they don't
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    Jan 2014
    Massachusetts USA
    782
    I, like many others, am running a Kenda front max 284 on my 84 200x. I have no complaints, even in short muddy sections. It steers well, and in the mud, I stand up, keep the weight but back, and it floats pretty well over the muck. The tire was only about $80 at the dealer, and it looks appropriate on the front of a vintage trike.
    1985 Tri-Z 250
    1985 ATC250R
    Blossvale NY
    4,563
    I have found that the Front Max has a fair bit more steering bite than the OE tire, mainly when the grooves in the tread are still fresh. Once the little grooves wear down, they are more even with the OE tire..at least in my experience.
    I haven't done a 10" conversion on any of mine, trivial and OCD as it may seem, I prefer the looks of the OE clover leaf cutout rims. I don't race so front tire selection isn't a huge deal to me and the Front Max serves my purposes beautifully.
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    Dec 2003
    australia
    838
    I'm in AU as well and I see the odd trike for sale down here with drive tyres on the front. I'm unsure how that would make the three wheeler handle, but it does look weird.
    If you look at how a tyre works under load, they all deform under load and in theory the flat wide tread used in a steer application has every chance to have good contact on the ground though a corner, depending on the surface, force, and speed applied to the tyre. So it is important that we don't just write of a tyre because it looks a bit wonky compared to what we a used to seeing. A "quad" drive tyre might work just fine.
    But having said all that I would be looking to replace my tyres with a tyre similar in construction to the OEM style of tyre. Those Kenda front max tyres seem to be the goods, and Can be bought via the Internet and arrive at your door step in a matter of days. That's the path I would be taking.
    Please don't try and repair a tyre with glue or heat. Some times, just sometimes, it makes a whole lot of sense to buy new. This is one of these instances.
    Sent from my iPad using Tapatalk
    My toys 85 KXT250A2, 85 ATC250R, 85 Tri-z 250, 06 LT-R450, 04 YFZ450S, 07 125 typhoon x 3, 06 FPV GT.
