DEBATE: Are quad tyres OK to use as FRONT trike tyres???
I'm in AU as well and I see the odd trike for sale down here with drive tyres on the front. I'm unsure how that would make the three wheeler handle, but it does look weird.
If you look at how a tyre works under load, they all deform under load and in theory the flat wide tread used in a steer application has every chance to have good contact on the ground though a corner, depending on the surface, force, and speed applied to the tyre. So it is important that we don't just write of a tyre because it looks a bit wonky compared to what we a used to seeing. A "quad" drive tyre might work just fine.
But having said all that I would be looking to replace my tyres with a tyre similar in construction to the OEM style of tyre. Those Kenda front max tyres seem to be the goods, and Can be bought via the Internet and arrive at your door step in a matter of days. That's the path I would be taking.
Please don't try and repair a tyre with glue or heat. Some times, just sometimes, it makes a whole lot of sense to buy new. This is one of these instances.
Sent from my iPad using Tapatalk
