Results 1 to 3 of 3
Thread: 85 Tecate 3 Carburettor
    Jul 2016
    Ontario, Canada
    91
    I'm looking at a new carb for my 85 Tecate 3. It is a Mikuni vm34-168. Just want to double check with the Tecate experts if this is a good choice for a stock bore engine.
    Thanks in advance!!
    Sep 2005
    MICHIGAN
    2,027
    Well the VM is often a good choice for fitting in the boots. You could consider a 36-38mm carb too. I believe Keihin carbs are shorter a bit and you have to stretch the rear boot some. I like Keihin cause they are easy to tune and dont leak. But a VM Mikuni is good choice for stock replacement. I personally would step up to 36-38mm but thats just me. Go to like Sudco site and check dimensions of carbs
    86 T3
    84 T3
    86 KX250
    Jul 2016
    Ontario, Canada
    91
    Hey Thanks nd4speed, I'll check out that site.
