Results 1 to 15 of 60
Thread: PA 250R mystery ATC
    Jan 2016
    Kirkwood,PA
    39
    PA 250R mystery ATC
    Hello members. I'm new to the site and I recently picked up a odd 250R. Please look at pics and help me to discover what we got. Looks to be a 81-82. No disk brake on the front, drum, all 250r had disk. Engine number reads 961AE-0020 which does not match any engine numbers that I know of. Who/why was the neck modified. Whos pipe is on it? Front and rear fenders are fiberglass. Plus more. SO lets see if we can get this figured out. Thanks in advance.
ID:	233362   Click image for larger version.
ID:	233363   Click image for larger version.
    Jan 2016
    Kirkwood,PA
    39
    Some more pics.Click image for larger version.
ID:	233365Click image for larger version.
    efhondakid's Avatar
    efhondakid is offline At The Back Of The Pack Arm chair racerFirst time rider
    Feb 2015
    Canton Ohio
    203
    I have a strong feeling this is a very good find. If I was to guess I would say it could be maybe a pre-production or some sort of factory race bike. The neck has to be to for adjusting rake/trail.
    2 in the back, 1 in the front.
    NEPA
    7,051
    SAE Bolts w lock washers,,,,anything Honda is out. The only way I can see to adjust anything would be putting washers in between the sandwiched metal plates,which doesn't seem to be happening there. Cool old bike.
    Jan 2016
    Kirkwood,PA
    39
    Found this on the inside of the front fender. Click image for larger version.
    Jan 2016
    Kirkwood,PA
    39
    Engine case with vin pic. I have yet to see a case that looks the same. The spud next to the flat plate is not molded to the vin area as are the 81-82. Hope that made sense. Click image for larger version.
    The Open Road
    4,736
    I know there is a department at American Honda Motors called Special Projects that was an R&D wing. Might be something important indeed
    The Open Road
    4,736
    To change the trail on that front end you would only need to slide the neck up or down. It doesn't seem like much but it raises the height enough to kick out the neck a few degrees. The front axle location being static means the trail changes and so will the handling.
    That's my uneducated guess
    Aug 2015
    Idaho
    838
    Is there a story behind the purchase? Might shine some light on your question.
    Looks like a special 'pick'. Congrats
    Jan 2016
    Kirkwood,PA
    39
    It was CL buy believe it or not. Still trying to track back through the people but it's not been easy.
    efhondakid's Avatar
    Feb 2015
    Canton Ohio
    203
    The next question is what did you pay for it? Haha
    May 2013
    Brownsville, Tn.
    1,271
    Kinda looks like a Bassani pipe.
    Cool find.
    * Nicholson 500 Race Bike *
    Jan 2016
    Kirkwood,PA
    39
    Quote Originally Posted by efhondakid View Post
    Ill just say it was a good deal for our area and for what it is.
    Jan 2016
    Kirkwood,PA
    39
    Quote Originally Posted by Joseph Farrow View Post
    Cool find.
    Any way to tell for sure? Is it stamped/has any markings to confirm this?
    Carthage NY 250r rules
    2,355
    Its 100% Bassani.I have one on my 85 250 r.Plus several members on AirFoolers.com have them on there 81-82 250 r.The silencer is the same style on all atc 250 r.
    250r rules
