Thread: how do i remove a stripped hex engine bolt
    how do i remove a stripped hex engine bolt from the head of my 200s? I stripped it with the allen wrench now i cant get it out?
    any ideas?
    Matt
    Mar 2003
    Australia
    1,919
    Try using vice grips or maybe file out two flat spots onto the edge of the bolts head and use a spanner.........
    matt
    1980 ATC 70 Needs Restoration
    1985 ATC 250es Fully Refurbed
    1986 ATC 350x Mint Original
    Nov 2001
    B.C.
    933
    Slot it with a Dremel, and use a screwdriver to back it out.
    Join The Trike Registry Now!
    http://fly.to/TrikeHeaven
    Re: how do i remove a stripped hex engine bolt
    Quote Originally Posted by honda200sx
    any ideas?
    Matt
    You may have a similar style mounting as my 250SX head does. Those allens are TIGHT!! And there is almost no room for anything to get in there and slot it or grind the head off.
    When this happens to me I usually grab the next size up standard allen wrench and using a bench grinder I will grind it down until I can smash it into the bolt real tight and that gets them out.
    Once it's stripped the correct size allen is useless. Grab a set of good allens and a new bolt.
    Good luck.
    Dec 2003
    98
    Depending on the size of allen it is, You may be able to a torx bit in it and it old to remove it. That is what I always due. The torx bit points will catch in the old corners of the allen head. It usually works.
    1986 Honda ATC 350X
    1983 Suzuki ALT 125
    2001 Eton RXL 90
    1998 LEM LX2 50
    1990 Yamaha PW 50
    1978 Honda CB750, Soon to be Chopped
    1968-71 Triumph 650 Custom Chopper
    RIDE IT LIKE YOU STOLE IT
    NICKG is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2002
    381
    well, this is what i normally do . if you can get a drill on it, drill thr head off the allen bolt, then take whatever it is that it hold on, by remoing the haed, you take the pressure off the shank. I usually just comes out with your fingers. if not, us vice grips. if you can't get a drill in there, use a 12 pt key(or torx) and drive it in. often you can also drive a bolt into it, then double nut it and remove it that way(like a stud). worst case, have someone tig weld the allen key into it, it will come out then
