Results 1 to 15 of 18
Thread: Need help motor problems 250es
    Jul 2016
    Winnipeg Manitoba Canada
    8
    Hey guys , I am working on my 1985 act 250es and it's missing/cutting out. Last season I rebuilt the top end and still has 165 psi compression. It's runs ok at idle or low rpm but as soon as the rpm pick up its cutting out periodically. It's not a steady miss, any thoughts on where to start ?
    Nov 2008
    IL/USA
    78
    I would start by cleaning the carb and making shure all the Jets and pick ups are spotless
    Sent from my SAMSUNG-SM-N900A using Tapatalk
    arlaunch's Avatar
    arlaunch is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2014
    Oregon City
    346
    Then replace the plug and set it to the correct gap if you have not done so.
    1984 Honda Big Red ATC 200ES (Emma)
    1985 Honda 200X ATC (Pretty Boy)
    1985 Honda 250R ATC (Dr. Fast)
    1985 Honda 250R ATC ( 77 )
    1985 Honda 250R ATC (Baller)
    1986 Honda 350X ATC (Go Go Girl)
    Feed Back: http://www.3wheelerworld.com/showthr...k-for-arlaunch
    Jul 2016
    8
    Quote Originally Posted by arlaunch View Post
    Yup I have cleaned the carb , changed plug and gaped correctly three times, I have also checked the valve clearance and it's perfect
    Sep 2012
    Indiana
    460
    I'd go ahead and order a rebuild kit for your carb, you would be amazed at the difference it could make. I use Shindy for all my rebuild kits.
    Wichita, Kansas
    1,361
    I'm assuming after the rebuild, it ran fine until recently?
    Check the fuel filter. Could be fuel starvation.
    Have you checked for air leaks between the carb and the head? If a gasket has failed or the boot has dry rotted, it could cause these symptoms.
    I'm leaning more towards the carb though.
    Jul 2016
    8
    Quote Originally Posted by RubberSalt View Post
    Yes it ran great for a whole season , I went to fire it up this year and the miss was there. I've cleaned the screen in the tank and the petcock. I've also torn down the carb and soaked in carb cleaner for two days. Do you think replacing the jets could do it ? They looked clean I could see through all the port holes with no obstructions
    Jun 2016
    Central FL
    38
    Sub'd!
    I'm having the exact same issue on my '86 250es! Replaced petcock, added inline filter, cleaned carb twice.
    Curious what you find, please post updates if you can as I'm stumped.
    ...Tools ...Toys (same thing)
    Jun 2016
    Central FL
    38
    Took carb apart again. Noticed the rubber plug on the second jet (added in '86 to block off the jet) was nearly disintegrated. Drilled and tapped the hole, and put a 5x.8 machine screw in there this time. I have to wait for a new bowl seal since it tore to see if it helped anything. I don't think it would since I believe that's the starter jet.
    Have you gotten anywhere?
    Jul 2016
    8
    I'm curious to see if that will work for you, I haven't had a chance to work on it again yet going Into it deeper tomorrow. Im going to check for any possible air leaks after the carb and maybe a loose fuel line letting in air.
    Do you think a lack of air getting to the carb could cause such a miss ?
    Jun 2016
    Central FL
    38
    Quote Originally Posted by Jobin545 View Post
    ...Im going to check for any possible air leaks after the carb and maybe a loose fuel line letting in air.
    I could wrong here, but since the fuel flows into the bowl and is then picked up I wouldn't think it would matter. But it would be strange to me that you would be sucking in air from a loose fuel line but not leaking any fuel when the motor isn't running.
    I've heard that if the big rubber tube connecting the carb to the head is cracked and sucking air that it can cause misses on the high end like we are having, but I've never experienced it and my tube is fine.
    Jul 2016
    8
    That's a good point ! , I do always shut off the fuel when I'm not running it , im looking at all options this one has me stumped.
    Yeah I have also herd of air leaks after the carb being an issue but mine seems to be in good shape too. I'm going to take the plastic flange that bolts to the head from the carb off and inspect everything with a fine tooth comb
    Wichita, Kansas
    1,361
    Any air leak after the carb can cause problems. Gasoline isn't sucked out, it's boiled out of the carb under the vacuum produced by the engine. This is why any air leak can cause problems. The vacuum produced wont be as strong.
    If the top of the carb is missing the seal, that can cause an air leak.
    A quick check for this is carb cleaner. Get the machine running, and spray carb cleaner around the intake boot where it bolts to the engine and the carb. Also make sure your spark plug is tight. The last thing is to check the cylinder head where it meets the jug. The gasket could be blown or the head bolts came loose.
    As for a cracked fuel line. It's unlikely that this would be the cause. The gravity fed fuel should move slower than the air bubbles can rise. I'd check and replace if it was a concern, but wouldn't worry to much about this.
    Jul 2016
    8
    Ok I will try the carb cleaner test tonight , if the head gasket was blown wouldn't it affect my compression ? And it's also very weird this problem popped up the first time I fired it up in the spring. The bike ran amazing all last season, but not this season.
    Wichita, Kansas
    1,361
    I'd think it would affect the compression, just tossing the idea out there.
    I could see thing dry rotting while sitting. You've already gone through the carb, so I'll rule out bad gasoline.
    You replaced the gas, right?
