Results 1 to 15 of 15
Thread: My new 250sx
    Jul 2016
    Washington
    6
    My new 250sx
    Hello all recently I purchased in 1985 250sx I was just wondering if you could tell me if there are any common problems or issues with this model I am thinking of fixing it up and using it for my main bike
    Queef Chief's Avatar
    Queef Chief is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2015
    Rineyville, KY
    231
    Most will tell you to change the differential oil right away. They're pretty solid bikes; I've never had an issue with mine.
    Dec 2015
    Louisiana USA
    30
    Change oil and plug and ride. I own two of them. I just restored one to showroom condition, it was my high school graduation gift in 1985.
    Feb 2013
    Senoia, Ga
    635
    I concur with what was said above. Keep all the fluids clean, and your good. I also own two, one of which, like Cajun ive had since new. They are a pretty rock solid trike.
    Maine
    463
    I own 2 also and they are good reliable machines. Just change the engine and diff oil.
    Current Trikes
    2 1985 Honda 250sx
    1985 Big Red
    2 1983 YTM 200k's. 1 for parts.
    KLT 250 Prairie
    1982 Honda 185 - Waiting to be saved
    1985 125m Parts Machine
    Still on the hunt for a 1986 350x and 250r.
    May 2009
    S.E. Michigan
    1,251
    Great machine! Just make sure to read up on how to keep the rear end dry and sealed. The 85 was a little different design than 86/87, and was a little more prone to letting water into the rear end. My policy is that if I go through any water, the rear axle lube gets changed. It uses very little, so this really isn't as bad as it sounds.
    Have fun!
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    Feb 2013
    Senoia, Ga
    635
    Quote Originally Posted by Jdare View Post
    Let see some pics!
    Sep 2012
    Indiana
    460
    Quote Originally Posted by Queef Chief View Post
    You still have that 85 that I owned once?
    Jul 2015
    Rineyville, KY
    231
    Quote Originally Posted by newby200x View Post
    Sure do!
    Jul 2016
    Washington
    6
    Thanks for all the input much appreciated I only paid 150 bucks for it
    Jul 2016
    Washington
    6
ID:	233488Click image for larger version.
    Feb 2013
    Senoia, Ga
    635
    Wow yeah, you stole that. I bet it will clean up nicely. Shoot, it beats the hell out of the $180 pile I bought some years back ( see my project thread in below my sig line below).
    Make sure you don't put a tire on the frt that is to wide I've seen 3 or 4 sets of forks that had the inside of the fork worn so bad that they had a hole in them. As for reliability keep it full of oil and it will out last you
    Jul 2016
    Washington
    6
    What size do you recommend for a frount tire?
    I just put new handlebars on and ordered a new starter solenoid now all I need is a set of tires
    Dec 2015
    Louisiana USA
    30
    22x11x8 oem size
