So I made new chain adjusters because mine are stripped out and can't get it to drive straight. I new the swingarm bolt was gonna be a pain. Beating on the socket over the nut then nut on the bolt then eventually just the bolt, got it to move 1/2 inch with the head mushroomed and threads toast. To make a long story a little shorter I finally got it by grinding the mushroom off then putting a socket over top the bolt so I'm already centered with my 1/2 inch punch, and using 5lbeasily drove it out the rest of the way, also sprayed with a lot of zep 2000 clear penetrating grease (amazing stuff).
I just took a 1/2 inch die to the bolt and reused it, also new roller bearings they were toast as well.
