Results 46 to 49 of 49
Thread: Will start but stalls almost right away: I'll explain more
  1. #46
    Newrider is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jun 2016
    New Jersey
    182
    U have no clue how grateful I am for your help.. Thanks so much
  2. #47
    Oct 2013
    Wherever I May Roam
    3,757
    Quote Originally Posted by Newrider View Post
    Now what should I do about this missing Bolt..
    Find one that fits. Do you have a Fastenal in Jersey? Pretty sure it's a 6x1.0 bolt with a 10mm head, not sure of the length. Wouldn't hurt to buy a few lengths, have some extra hardware on hand. Very common metric bolt size. It also uses a washer.
    Thanks so much
    No problem. Here's the 200s manual. Read and understand, and ask more questions when you need to. Don't forget to set your valve clearance per the instructions in this manual. http://www.oscarmayer.net/atc/manual...ice_Manual.pdf
    Also, dont forget to torque the cam sprocket bolts (dab of loctite wouldn't hurt), and the advancer bolt. You'll have to hold the flywheel stationary to do this.
    Good luck.
  3. #48
    Jun 2016
    New Jersey
    182
    I wanted to thank you again.. I just need to adjust my valves which I will do tomorrow after work I got the bolts like you said and I bought a whole hand full in different lengths and fit one along with a lock washer and wow the pull starter doesn't rip my arm off anymore and she started with one pull.. I must not have read about my valves yesterday but when I heard the motor ticking I came back to this thread and read the Honda shop manual.. So I'll get a feeler Gage also tomorrow.. You saved me a big headache dohcbikes.. My names mike and I thank you
  4. #49
    Oct 2013
    Wherever I May Roam
    3,757
    Hey man, that's great!
    Many more threads could end up this way if people were as receptive and willing to follow directions and post pics as you are. It really helps. Not everything can be solved, but something can always be learned. It's nice to know when advice is appreciated and many these days are too proud to acknowledge it, so thank you, Mike. -Damon-
