Page 2 of 2 FirstFirst 1 2
Results 16 to 23 of 23
Thread: Carb adjustment advice. 1983 200X
    May 2016
    OH Canada
    1,102
    Finally got to work on it tonight. Made 1 carb out of 2. Swapped the parts that I needed from the new carb. (Slide, pilot screw...spring..o-ring, idle screw) Put them into the OEM carb.
    Fired up good. Very happy with it. Getting some guys together this weekend to go out for a rip.
    Apr 2015
    San Diego
    26
    That is always a great feeling.
    As we get closer to desert season I have to get 4 quads already to go. My 4 stroke quad is not to bad. I ran the gas out of it last season. Everyone else's bikes will need carbs and gas tanks cleaned with the normal maintenance stuff like spark plugs, oil and filters. Sometimes I wish I did not know how to work on bikes 😵😵
    Congrats and have fun this weekend.
    David...
    May 2016
    OH Canada
    1,102
    Quote Originally Posted by wrightracing View Post
    As we get closer to desert season I have to get 4 quads already to go. My 4 stroke quad is not to bad. I ran the gas out of it last season. Everyone else's bikes will need carbs and gas tanks cleaned with the normal maintenance stuff like spark plugs, oil and filters. Sometimes I wish I did not know how to work on bikes ����
    David...
    Thanks.
    Just ordered up stuff for my front end. Bearings and fork seals. I did a bunch of stuff to it during the summer. Rear bearings, brakes, chain and sprockets, coil, CDI unit as well as maintenance stuff. It has new hoops on it. .
    Apr 2015
    San Diego
    26
    This is my old beast. I could ride all over the Dunes at Glamis and keep up with all the fast 2 strokes by taking straight lines through the dunes.
    They are a blast.
    I have a 86 TRX250R that I have just done a Frame up restoration with a Vulcan Black powder coated Frame, brand new CT310 2 stroke motor and all new White Brothers shocks front and rear. I have also picked up a CR500 38mm Carb with the Magura twist throttle. I have a major hatred of thumb throttles. I grew up racing dirtbikes in Baja and the desert, so I convert all my bikes over to twist. Even the 2005 400ex for my Mom was converted before she ever rode it.
    Let us know how the weekend goes..
    David (david@wrightracing.net)
    axeman24 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2016
    long island NY
    247
    You likely have an airleak or your needle jet needs to be replaced.
    I think you were correct with the air leak
    when taking off the carb to recheck jets and such I noticed the intake boot was a bit loose it looks like one end came apart where the metal end attaches to the rubber body
    I replaced it with a good spare I got in a box of parts from captainweezy (thanks again)
    put it together and she fired as normal
    took her for a test ride ran good but felt a little weak at top end
    after about a half hr I shut down with the kill switch
    when I tried to restart she seemed flooded the only way I got it started was a pull stat from another bike(flooded for sure) but ran well after that
    the next day I took her out rode hard for a bit
    but she started bogging out
    my current situation:
    she will start with half throttle but its a very low rpm(lower then she has ever stayed running so I think the new boot helped one issue) and sounds like its missing fire strokes
    any change in throttle or choke she dies
    blowing black smoke in-between sputtering fires
    it almost reminds me of a hit or miss motor the way it sounds
    I have a video I could send if it would help diagnose my issue
    could my issues be coming from a weak coil?
    changed the plug no change
    I will swop the carb with a good running bike to rule out a spark issue
    Aug 2016
    long island NY
    247
    Update I do not have spark anymore so it must be the coil???
    I am now out of my comfort zone I am terrible with electrics
    Please help
    May 2016
    OH Canada
    1,102
    Went for a solo run. Ran up with some peeps on the trails. I had a blast!!!
    TwiZ's Avatar
    TwiZ is offline At The Back Of The Pack Arm chair racerFirst time rider
    Sep 2015
    Elk county Pa.
    187
    Quote Originally Posted by Honda200xrace View Post
    I had the same idle issue you did. Ordered a new carb thinking i could just use the slide out of it and they were different. Didnt want to swap carb because i have rejetted it. I took a dremel and lightly ground my slope it seemed to fix my problem for now.
    The problem i see is the metal seems softer under the chrome finish so it will wear/dent easier again
    . I know this post is a bit old but.....To keep the issue of the marks or dents getting the slider scarred up i always push the throttle in a little before i turn the idle screw in,just shut machine off and give it a tiny little turn clockwise. That lifts the slider up off of the adjustment screw as you turn it
    1984 Honda 200X
    1984 Honda 200S Bonecrusher
    1975 Jeep CJ5
