Not an electrical guy and going nuts here. 1985 ATC 70 been sitting for a few years. Replaced plug wire/coil, condensor, points, stator coils, cleaned flywheel magnets/stator enclosure, set point gap to 0.14, NGK plug set to 0.28. Getting fuel, getting air, have compression. No or weak spark. Plug doesn't fire but I can stick a screw driver in the plug wire and get a weak spark occasionally. Bought a Spangler 70 stator rebuild kit and nearly had a stroke after it still didn't fire. No lights installed. One wire going from the kill switch to the engine and one wire coming of the ignition coil tied to it going into one and plugging in the wiring harness. Any ideas appreciated, I'm at a loss. Thanks
