Hey I was wondering how big the ballon tires are. I know you have to use the wheel that the tire is mounted on,but do you have to use the hub also? And will the wheel mount up to an 84' 125m hub? And what is the bolt pattern on the wheels? thanx
"I am going out of this world.....the same way I came in...screaming and covered in blood."
The old balloon tires are 22x11x3.5 They use a special hub with a special style axle splines. With out making special adapters they will not fit a 125m hub.Originally Posted by hondatrikesrule22
Thanks
Howdy
Ok that is what I figured, would the wheel,tire and hub assy. mount up to 125m forks? And what about the rear tires,do you have to use those hubs also or do they mount up like regular tires? thanx
